Old 02-17-2012, 03:31 PM   #21 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
jakobnev -
Originally Posted by jakobnev View Post
cfg83 -
The table screams it.
Ok, unicorn until proven otherwise. The test needs to be done by an independent lab. And then we have to research the lab to make sure it's not a rubber-stamper.
CarloSW2
American Solar Energy Society
Old 02-17-2012, 09:02 PM   #22 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
I'm kind of curious about the noise reduction aspect. If their claims are true, you'd get the performance increase of a baffle-less muffler (weight and reduced back pressure) but the same sound deadening as a baffled muffler.
Old 02-18-2012, 12:52 AM   #23 (permalink)
it should be pretty quiet, with a ton of back pressure.
It is interesting they can get a diesel to run with so little free oxygen.
Old 02-18-2012, 10:38 PM   #24 (permalink)
Again, I've seen AFRs change by that much with simple exhaust modifications, and the AFR change alone would cause those HC and CO changes due to the leaner running... but never with something that's supposed to reduce sound. There are header designs that are well-known to cause leaner running.
