Old 02-04-2010, 07:22 PM   #111 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
If I recall, the Metro problem is a coked up EGR passage that affects the middle cylinder. The result can be a burned exhaust valve (since EGR reduces combustion temperatures, without it, things get too toasty).
Old 02-04-2010, 09:37 PM   #112 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
That seems to be what they say, that I've heard anyway.
Daox - For the care, cleaning, and maintenance of your system, short and straight as possible. There's nothing fluid, and unless you're going to filter it through water or some other fluid medium, or add in filters/screens, etc... just pipe it all in there, and maintain it accordingly. You'll be checking on it all the time anyway, I'm sure, so you'll get a feel for how long it takes before it needs to be cleaned out.
EGR cleaning should be a part of vehicle maintenance for anyone that does alot of cruising at steady speeds. It seems that those vehicles see coked EGR's the most, at least to me.
Old 02-05-2010, 10:13 AM   #113 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
As Christ pointed out, the MAP sensor will not sense it. I removed this part from my post.
EGR works as long as the pressure in the exhaust manifold is higher than the pressure inside the intake manifold. It is possible to have significant EGR levels at WOT and even at positive intake manifold pressure. In fact, diesel engines always operate EGR with positive intake pressure.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 02-05-2010, 11:47 AM   #114 (permalink)
Without sounding pompous about it - doesn't an engine, by design, always have higher pressure in the exhaust than in the intake?
Barring a few very special situations, I can't think of a time that for it to be running properly, it doesn't have more pressure coming out than going in.
I don't fully understand EGR, so that's not a rhetorical question, and I don't mean it to come off that way.
Old 02-05-2010, 12:37 PM   #115 (permalink)
I just wanted to express my view as to whether EGR is drawn by vacuum or forced by pressure. My comment was merely academic as we were talking about the same net effect anyway.
Old 02-05-2010, 04:17 PM   #116 (permalink)
I'm not understanding why this is. I'm cruising along at part throttle, so I have vacuum in the intake manifold. Then, I open up the EGR valve a bit. This is going to reduce the vacuum. The MAP sensor should see that.
At full throttle I could definitely imagine seeing positive pressure in the manifold, but I don't see that happening any other time than that. I guess I was also under the assumption that exhaust pressure was always higher than intake pressure as well.
Old 02-05-2010, 05:18 PM   #117 (permalink)
Won't your MAP think more air just went in and the ECU would adjust the fueling accordingly? Your o2 sensor would pick it up though, setting the record straight trimming the fuel, but maybe that would throw a MAP fault code.
Here's an interesting article on EGR control strategies.
Old 02-05-2010, 09:52 PM   #118 (permalink)
It's a thought... I'm not totally sure about it.
I don't really think that adding EGR is going to reduce the vacuum, because it's just adding mass from an area other than the throttle body. In other words, the engine is still drawing the same vacuum on the manifold, but the EGR is basically a second intake source. While you would show less flow through the throttle body, the vacuum figure should be the same regardless of EGR flow. (Some fluctuation might be noted due to expansion of heated gasses, etc.. )
Old 02-06-2010, 09:07 AM   #119 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I'd expect a reduction in vacuum with EGR. Since EGR reduces power, you'll have to open the throttle further to maintain the same speed. And the EGR flow you're letting into the intake manifold is higher pressure than the ambient pressure entering the throttle body, so that alone should decrease vacuum even if throttle position remains the same.
Also, the ECU in Suzukis (as well as other cars) uses the MAP sensor to monitor EGR function. If the ECU doesn't see the expected change in MAP when the EGR valve is told to open, you get a CEL. But from what I've read, it's a very small change in vacuum. But if you're increasing EGR flow, that could change.
Old 02-06-2010, 05:16 PM   #120 (permalink)
Well, another option might be feeding the exhaust into the intake tract, upstream of the throttle.
Though that might mess things up because of the intake air temp (IAT) sensor ...
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
