Old 08-24-2015, 10:51 PM   #21 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
That sucks about the jacked up registration!
If they are RE92s and they have no cracks, try 50-65 psi FTW!
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following User Says Thank You to BabyDiesel For This Useful Post:
pgfpro (08-24-2015)
Old 08-24-2015, 10:54 PM   #22 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I forgot to mention I had to leave the DMV due to a work emergency so I didn't get the car registered. I'm will try again tomorrow and let everyone know what the cost is.
Pressure Gradient Force
The Positive Side of the Number Line
Old 08-25-2015, 07:42 AM   #23 (permalink)
Probably needs the egr passageways cleaned.
regards
mech
pgfpro (08-25-2015)
Old 08-25-2015, 08:11 AM   #24 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
regards
mech
Thats on my to do list
Old 08-25-2015, 11:11 AM   #25 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Woo 28psi? I would recommend going 45. 28 to 45 is probably a 5mpg increase itself.
The Following User Says Thank You to Baltothewolf For This Useful Post:
pgfpro (08-25-2015)
Old 08-25-2015, 02:53 PM   #26 (permalink)
Ditto to Balto's advice. Maybe an alignment or at least a tape measure check. EGR plays a huge part in lean burn. Maximize the gliding.
regards
mech
pgfpro (08-25-2015)
Old 08-25-2015, 03:55 PM   #27 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
I'm going to take your advise Mech and do the EGR cleaning this weekend. I drove it around this morning after fixing the tire pressure and it still seems to be still struggling keeping in lean burn. I also did a compression test and everything checked out fine.
Old 08-25-2015, 05:31 PM   #28 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
The EGR plate is pretty easy to clean, and I re-used the metal gasket with no issues on mine. More than likely the problem is the EGR valve itself, though. I got one for Ron Burgundy for like 55 bucks with a gasket and it works great, here's the link http://ecomodder.com/forum/showthrea...tml#post474729. That's a five minute fix, while the plate cleaning takes about an hour
You'll need one of those knuckles to be able to remove a couple of those bolts on the EGR plate btw, and keep a magnet handy for when you drop one into the bottom pan
I keep my RE92s at 60 psi with no ill effects, I kept the Maypops on the Festiva at 50 psi and never had an issue with them either.
The Following User Says Thank You to cowmeat For This Useful Post:
pgfpro (08-25-2015)
Old 08-25-2015, 06:51 PM   #29 (permalink)
Furry Furfag
I also run 60, but I don't recommend it to people as you lose A LOT of braking grip at 60 vs 45.
Old 08-25-2015, 07:10 PM   #30 (permalink)
cowmeat's Avatar
Maverick Hybrids
Yeah, what he said!
I rarely use the brakes considering my commute and the fact that I have a regen button on my shifter that does the braking for me, but there definitely is a fine line between max mpg savings and safety that you don't want to cross just to save a few bucks. Even when I ran mine at 45 psi I did okay.
