Old 03-05-2014, 02:11 AM   #31 (permalink)
Dutch advances
Since Theo22 has been shy about posting in the discussion, I'll just spill the beans.
In PM's with Theo22, he basically confirmed they have been using stall strips on their human powered velomobiles. Except they call then "Storm Strips".
I Googled the term and found at least one Dutch blog. Using Google translate you can read the Dutch blog. The translation is a bit rough but with effort, you can glean the basic meaning.
Google Translate
Another blog is here with Google translate. Again, the translation is a bit rough.
Google Translate
Earlier I stumbled on another page which I believe is Theo22 and Allert's velomobile company in which they (re)sell the strips. I can't find the page again. If I do, I'll post it.
This Dutch discovery basically proves that stall strips are at least one aero fix to streamlined motorcycles.
There must be more though and we should continue looking.
-- Teri
The Following User Says Thank You to Teri_TX For This Useful Post:
Ironside (03-05-2014)
Old 03-05-2014, 08:07 AM   #32 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
What are the requirements? Why are you discussing random band-aids (vortex generators?) when you don't even have a motorcycle, let alone any experience driving one, and most egregiously you are talking about these without a fuselage to apply them to. If you thought coding had a lot of variables, welcome to aerodynamics, where you don't get to make any assumptions without testing.
Well actually, you can, but you have to rely on dread software (4d flow modelling software, open source available) to do it and start refining an ACTUAL design before you can validate any changes, but still the proof will be in the pudding.
Aeromonkeys, sheesh. Just because one guy put a "fence" on his cycle, doesn't mean it will help random design X. The monotracer folks ACTUALLY tested their design in controlled crosswinds, and they have 1000 pounds of weight on their side to help w/crosswinds (and riding experience).
I don't care if you put rudder pedals on your bike to move a control surface, you will still be better off if you can react aerodynamically to an aerodynamic input.
Old 03-05-2014, 08:25 AM   #33 (permalink)
P-hack's Avatar
OpenFOAM&#174 - The Open Source Computational Fluid Dynamics (CFD) Toolbox <- not for monkeys
Old 03-05-2014, 08:33 AM   #34 (permalink)
Fellas, lets settle down and be objective here (without being derogatory). Thanks.
Old 03-05-2014, 04:19 PM   #35 (permalink)
Yella Peril - '80 Mercedes 240D sedan
My preference is to reduce the aerodynamic reaction .
My current preference is for a flat sided fairing with covered openings, something that wouldn't generate the side lift to start with.
Old 03-05-2014, 04:48 PM   #36 (permalink)
P-hack's Avatar
It is worth considering what an "optimal" arrangement is as well, I don't know that this is aerodynamically optimal, just thinking out loud. If the requirement is be as streamlined as possible, even in a crosswind, then this is what comes to mind. (naca 0018) top view
Old 03-05-2014, 05:07 PM   #37 (permalink)
P-hack's Avatar
here is a really good link too, with much that has already been discussed.
Delta Bike USA - Forge Design Competition A - Cross Wind Stability
monotracer leans automatically into the wind, but still gets pushed sidways. Also worth nothing that leaning into the wind creates a pocket of high pressure with an upward vector, removing weight/traction from the wheels, ok on a 1000lb bike, but...
Old 03-05-2014, 06:35 PM   #38 (permalink)
Here are some random thoughts mostly about mitigating crosswind dammage, than finding a perfect solution for it.
I would say increasing the dynamic stability of the bike will gain you a portion. A more advanced independent suspension, steering geometry, wheelbase and weight distribution will improve crosswind stability. Which begs the point that the "optimal" donor bike would need to be modified or custom made. As far as weight distribution, i've seen custom rigs where the driver almost sits over the front wheel. Others have the drive sitting low in the frame.
Weight is a big deal. There was a nearly completely enclosed motorcycle that drove coast to coast on one large tank of gas. It was more stable full than empty. Electric motorcycles are the best clean sheet approach. You have 200 or more pounds of batteries that can be optimally placed for stability.
The simplest solution is the Bebe Pulse autocycle with two outriggers made from trailer wheels. Making a non optimal form like Vetter's Honda Helix with openings (to counteract sidewinds???) is less effective than adding frontal area in outriggers and doing a completely enclosed streamliner. It would also be more commercially viable in cost and in the low driver skill involved than the Monotracer.
The nose is where you can affect crosswind stability without adversely affecting aerodynamics. I like Teri's thoughts on this. A rounded radiused nose is best for crosswind on cars cause it easily passes air from side to side. but on a tall thin bike you want something that equalizes the air pressure on either side. The wind blowing you is manageable. The suction on the other side, being multiplied by speed is the BIG issue. That is the real root of the problem! Suction, suction, suction!
I've thought about small deployable airflaps perpendicular to the airflow to ruin your aerodynamics when neccesary. Crosswinds are not an everyday issue. The last resort would be to just kill your aerodynamics when absolutely neccesary.
I try to be helpful. I'm not an expert.
Old 03-05-2014, 10:34 PM   #39 (permalink)
Best solution for stability is down force from race car design. Shape laterally can be rounded to reduce lift and drag.
Old 03-06-2014, 02:49 AM   #40 (permalink)
Hi Sheepdog,
I'm not following you on the more advanced suspension. Other than the Hossack,there's not a whole lot you can do. Tony Foale did say in one of his articles that excessive trail was bad in crosswinds. Without making an "Easy Rider" chopper, "sport bikes" have fairly small trail to my limited knowledge of motorcycles.
Interesting that you mention weight, maybe the Monotracer's are "so stable" is because of their massive (~1000 lb. + riders) nature and limo-like length wheelbase. Calling them motorcycles is stretching the term in my opinion. I didn't realize at first how big they are until I saw a picture of a motorcycle beside one.
Vetter had to add some weights (18 lbs.) to his nose to damp the transient effects of cross wind gusts. It increased the polar moment of inertia.
The simplest solution is the Bede Pulse autocycle with two outriggers made from trailer wheels. Making a non optimal form like Vetter's Honda Helix with openings (to counteract sidewinds???) is less effective than adding frontal area in outriggers and doing a completely enclosed streamliner. It would also be more commercially viable in cost and in the low driver skill involved than the Monotracer.
I read that the outriggers are a problem on the Bede Pulse http://www.autocycles.org/pulseoutrigger.html They experience high wear. I also understand they are tricky in a spin. A bike just drops which is no better. A relatively narrow motorcycle is appealing for lane splitting, otherwise, just go for a trike which the states recognize as a "motorcycle" for licensing purposes. I'd be reluctant to split lanes if I rode a motorcycle although tempting if stuck in traffic.
Motorcycles have a problem in the rolll axis from cross winds. It's inherent. Trikes don't have a roll axis problem except maybe in severe cornering if they are too narrow.
I'm not crazy about Vetter's gaping sides personally although it probably appeals to his open motorcycle mentality. This was all he could do without some other solution unknown to him. Stall Strips Remember, he's a motorcycle fairing designer, not a rocket scientist.
I personally think Creasey's Voyagers are something only it's mother could love
On a conventional aircraft wing, the leading edge (nose) is especially critical for lift, that's why it's heated (on jets) or has pneumatic de-icing boots for icing conditions. Practical considerations dictate streamlined motorcycles have a somewhat bulbous nose (for our bodies behind) compared to the overall length. That being said, I believe some aero fix is required especially on the nose (leading edge). A gaping hole like Vetter's is one way but not elegant. I don't think there is a perfect solution where cross wind effects disappear since we still have the sideways bluff body to blow around. Remember traditional kites fly with flat surfaces.
I've had similar thoughts about manually deployed spoilers but Vetter lives in a place where it's an everyday problem. Where I live, the winds blow fairly consistently about 15-25 mph from the south and the roads are not very twisty. Vetter also experiences rapidly switching direction winds as well. Getting caught with your spoilers not deployed could be exciting (in a not good way!)
Theo22 in PM's has said his Evo-like motorcycle (same Honda as Allerts') Cathelijne » e-motion is controllable in highly turbulent air from passing 18 wheelers. He attributes this to the relatively poor aerodynamics but is willing to give up low drag for less cross wind sensitivity. He chose lower frontal area instead of lower Cd. He said that in over 20 years of designing streamlined velomobiles, he and Allert have concluded that the better the Cd, the more sensitive it is to cross winds. They have over 20 years of experience. Don't discount that lightly.
As I said in my opening post, U2 pilots have a deployable stall strips and spoilers during landing but this is in a phase of flight where much concentration is required (not that the U2 is an easy plane to fly anytime).
I still think there is something that is completely passive automatic like stall strips or similar. They are there all the time and working without any thinking or you could have exotic failure prone electro-mechanical solutions.
-- Teri
aerodynamics, allert, vetter fuel challenge, wind tunnel testing
