Old 04-18-2020, 10:35 AM   #61 (permalink)
Attaching a vacuum pump to the vacuum reservoir. If it doesn't have a vacuum reservoir, add on.
Yeah permanently disable the v8 mode by going to a 4 cylinder hybrid car.
Xist (04-19-2020)
Old 04-18-2020, 01:23 PM   #62 (permalink)
Just add a reservoir (vacuum tank) and be done with it.
Take a scrap piece of 3.5”- 4” PVC pipe a couple of feet long, glue on some end caps then drill a hole to attach a fitting and connect to your existing vacuum system.
No need to delete anything and it won’t affect the smog test.
Easypeasy...
Old 04-19-2020, 04:27 PM   #63 (permalink)
So... how much vacuum could that store?
Old 04-19-2020, 06:02 PM   #64 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
A lot! More than you'd think.
Old 04-21-2020, 09:32 AM   #65 (permalink)
V=pi*Rsquared*height. So 3.14x4x12=150.72 cu inches a running foot for 4" pipe. My reservoir in the ranger is 2 ft long and I get 3 applications of the brakes on a leaky booster
aerohead (04-22-2020)
Old 04-25-2020, 02:06 AM   #66 (permalink)
Originally Posted by Tahoe_Hybrid View Post
I thought about using some 2015 model they are smaller and more Aero shaped but it would really kill my budget it's like 300ea since i have DL3 mirror trim level
That's why I'd try the mirrors of some sports motorcycle, as they might be easier to find for a considerably lower budget.
Everything nicely tucked in above the frame including the drive shaft, tell the rear differential pumpkin.. slightly sticking out
also the belly pan would need an access panel for oil changes i do them every 4500 miles or so+- 100 miles
Figuring out how to get the access panel doesn't sound like rocket science. I'd still consider a belly pan.
Old 04-25-2020, 01:01 PM   #67 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Also, they make these really great things called screws. They make things easily removable.
Old 04-26-2020, 10:23 AM   #68 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
i could always save up the money for the lower profile mirrors.from the newer model.
the belly pan is a good idea it will need some air flow to prevent the gas from boiling(i live in the desert it gets upto 110-115 in the summer 90-100f is common)..
how do go about fixing the rear as the air issue (the air from the underbody gets shot straight up in the air exiting from the rear end) i guess this could be a significant source of drag
Old 04-26-2020, 11:15 AM   #69 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Is there a high pressure fuel pump in the tank? This has largely removed vapor lock in modern cars. Also I believe there is a return line so fuel should always be circulating to the tank, helping keep the lines cool. Insulate the fuel lines if necessary.
Read up about rear diffusers. Ideally the rear 1/3 of the full belly pan should taper upward slightly. Aerohead has suggested 5 degrees above horizontal is best for low drag. This reduces lift and drag and helps fill the rear wake.
Belly pans from the manufacturers leave the exhaust uncovered. This allows heat to escape while giving much of the benefit of a belly pan.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Last edited by COcyclist; 04-28-2020 at 09:31 AM.. Reason: We started down a rabbit hole about boiling gasoline
The Following User Says Thank You to COcyclist For This Useful Post:
aerohead (04-29-2020)
Old 04-26-2020, 01:57 PM   #70 (permalink)
got a check engine code nothing specific generic P0430 that is it
it says my fuel trim went to 34+ :O
MPG dropped as i have No auto stop to
17.5MPG
gotta replace the MAF/IAT as it's broken going to order it on friday
unicorn corral
