08-19-2014, 05:34 PM
#21 (permalink)
Bsfc
So 2,000 rpm is the 'sweet-spot' for your engine.That's nice to know,and worth publishing at the BSFC thread at one of the other forums.
08-20-2014, 12:12 AM
#22 (permalink)
Originally Posted by elhigh
I hear you about the no mods on the Miata, but speed = power. If you need less power to hold speed (due to aero mods, for instance), that means more ponies available to pull you around the curve to the next one.
Like the little mini-kamm. A lot of guys here have done mini-kamms and gotten good results.
By no mods I meant nothing extreme
Front airdam and mini-kamm are both "mandatory", I like the look of them. At first I thought the mini-kamm looks good but then I noticed the shape and thought it's also a useful mod.
Yes, looks like it. Now I understand why when I bought the car and brought it home (600 high-way miles) I was cruising between 2000 and 2200 rpm. And I got my best mileage to date... a bit under 30mpg.
Back on topic: I got most of the airdam done, just need to finish up the mounting and add a small downward lip. I could not bend the plastic sheeting so the airdam covers only half of the tire width
Pictures later
The Following User Says Thank You to AdrianD For This Useful Post:
08-20-2014, 12:32 PM
#23 (permalink)
This is how the airdam looks. Very easy to install/uninstall.
If only i could've bent the plexiglass and covered more of the front tires...
Grill block coming up tomorrow. I'm going to steal the idea of another member and make 'plugs' for the small grill openings. Given that it's hot outside, i will only block 4 out of 7 openings.
The Following 2 Users Say Thank You to AdrianD For This Useful Post:
08-21-2014, 04:05 AM
#24 (permalink)
Originally Posted by AdrianD
Garrett claims that they can deliver improved mileage by means of VGT because of reduced backpressure when cruising. So only one way to find out...
In my country, there is a company that offers a range of turbos focused on fuel-efficiency, but they're fixed-geometry type instead. One thing I am still somehow afraid regarding a VGT is the carbon build-ups.
08-21-2014, 04:11 AM
#25 (permalink)
I hope a spirited acceleration once in a while (to push EGT over 1000*F) and a few full open/close cycles after shut-off, forced by the controller, will keep carbon build-up problems away.
Do you have anymore details on those turbos?
08-21-2014, 09:38 PM
#26 (permalink)
Search for the Ecoturbo Biagio. Not sure if they export directly to Europe, however...
08-22-2014, 01:01 AM
#27 (permalink)
Lots of Questions
Any pages about the Biagio that happens to be in English?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
08-22-2014, 02:53 AM
#28 (permalink)
Sure
ECOTURBO BIAGIO - GIVE MORE LIFE AND LONGER FUTURE TO YOUR TRUCK |
But don't get so used, I won't be spoon-feeding you forever
08-25-2014, 06:27 AM
#29 (permalink)
Looks like the roads to greece have not been mileage-friendly. 4 peoplr in the car, full trunk ,about 200 highway miles and 400 miles of 2-lane roads, bad surfaces, passing slow cars, speed limits and so on. Right before i left, i took the jeep to a carwash and the guy there managed to break 6 inches from the airdam.
I estimate about 27mpg over the last tank, considering the road to the beach everyday is a mountain road. Not bad though.
Other numbers: 4psi cruising on flat ground at 62mph (2000 rpm), EGT 600F.
At least the view om the beach is good
