Old 03-03-2011, 03:39 AM   #1 (permalink)
Just made these. feedback required... (Miata/MX-5 front tire deflectors)
Hi Guys/Girls...
Fuels finaly hit £1.30/litre. A*se.
My MX5 (Miata) has really exposed front tyres, so yesterday I made a pair of these (see before and after photos...)
I would like to tidy the fixings up a bit ie, make them smaller/lighter.
Before...
After...
I used a store bought clear material labelled as 'polystyrene'. It was certainly flexible enough, but produced tiny cracks when cutting. It was 2mm thick.
What other products/materials would suit this application?
Have I made something worthwile?
Thanks in advance, Ian
Old 03-03-2011, 09:12 AM   #2 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
i'll give you an "A" for the concept of deflecting the air around the front tires and a "C" for execution of concept. I've dealt with polystyrene alot (i built tons of plastic model cars growing up) and i have to say it is likely too flimsy to suit your needs in this case. i would suggest finding some 1/16"(1.5mm) Plexiglass to use instead of the styrene. I'm sure the guys on here know of a few other materials you could use. it's a good start for what your looking for and it's a good thing to look at (i'm going to put something similar on the side of the airdam on my Jeep) since it should reduce drag caused by the tires
The Following User Says Thank You to Joenavy85 For This Useful Post:
caferacer51 (03-03-2011)
Old 03-03-2011, 09:37 AM   #3 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
you may want to have a look at (what toyota calls) 'aero corners'
they have recently appeared on a lot of aerodynamics cars like the new prius, iq, citroen ds3, and some others.
basically the corners before the wheels are squared off, sometimes by agresively styled daytime light, what looks like air scoops or just add-on like bumps in case of the IQ.
but all designs seem to create a sharper corner and a more flush pannel leading up to the wheels.
this aero corner thing seems fairly new and appart from a general description i don't have much info on it, but the fact it's on cars like the prius sugests there's something good about the design.
it may also explain why some olders cars managed to get a very good Cd with relatively square fronts... perhaps 'making the front as smooth as possible' is not always the best strategy
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
The Following 2 Users Say Thank You to lunarhighway For This Useful Post:
PaleMelanesian (03-04-2011), Piwoslaw (03-03-2011)
Old 03-03-2011, 10:20 AM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
I think the material you are looking for is polycarbonate. It doen't crack like an addict when bent or machined.
The Following User Says Thank You to jakobnev For This Useful Post:
Old 03-03-2011, 10:42 AM   #5 (permalink)
^^That's one of the one's i couldn't think of^^
Old 03-03-2011, 04:12 PM   #6 (permalink)
fidalgoman's Avatar
What you've done reminds me a little bit of NASCAR air dams. There is a lot that can be learned from racecar aerodynamics. Smooth contours, diverting airflow away from dirty parts of car (like undercarriage), not making the airflow to bend any more than necessary and eliminating extremes in pressure gradient distributions, etc. However there are things that do not pertain to those of us on the street doing under 150 MPH.
First racecars are obsessed with down-force to create high cornering loads. Many rules today are there just to eliminate that technology thereby slowing down the cars. Most racecars are so overpowered that just getting the power to the pavement is a real problem. One that we don't have. Also racecars (that resemble street cars) have quite a few restrictions on what they can and cannot do as far as changing vehicle profile and airflow around the car. Again that's mostly not a problem for us.
For us it's all about eliminating drag. Drag comes from changes in flow, both directional and pressure distributions. Anything we can do to create equilibrium and smooth contours only helps us. Anytime the airflow has to work through changes in direction, slowing down or speeding up, it extracts energy from the airstream. That energy (often called drag) has to be made up through our propulsion system. That in turn requires fuel which we all know is something we are trying to avoid.
Old 03-03-2011, 06:07 PM   #7 (permalink)
perpendicular impact
Originally Posted by caferacer51 View Post
Hi Guys/Girls...
Before...
After...
Ian,you're doing a good thing.Ideally,as in solar race cars for example,complete shielding of the tires from the airflow cuts drag.
At say,100 km/h,the forward face of the front tires are travelling downward at 100 km/h and impacting the air perpendicularly at 100 km/h.It's a situation which makes it impossible for attached flow.
Your shields will kick the air out and around the tires where it can flow to the rear.
If you were to do likewise for the entire sides of the Miata you'd gain even more.GM measured improvements this way with its Trans AM Firebird.
California98Civic (03-11-2011)
Old 03-04-2011, 01:19 PM   #8 (permalink)
Thanks all for the replies and info.
Think I'm gonna make a more polished version from better materials.
Will have a think what I can do with the rear wheels? Not sure I fancy fully faired in. But something similar to the front?
Old 03-04-2011, 01:37 PM   #9 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Great Idea. I was wondering is Lexan a trade name? I saw some Lexan on sale at Lowes and it says it 10 times stronger than plexaglass.
Does anyone have experience with using Lexan?
Old 03-04-2011, 03:09 PM   #10 (permalink)
Bookworm
Sylvio 2 - '04 Audi allroad quattro Biturbo 6-spd
90 day: 25.09 mpg (US)
Atlas - '04 Audi allroad 2.7T 6MT
Lexan is a trademarked name for polycarbonate sheet. It's softer & scratches more easily than Plexiglas (a trademarked name for acrylic sheet), but it has much better impact resistance than plexi.
On a different note, I'll be interested to see how the Miata project goes. I think there's some real potential for hypermiling the Miata.
I'm planning to put a grill block and belly pan on mine, and maybe some removable fairings around the wheel openings. Maybe I could justify buying a Speedster tonneau cover on fuel efficiency grounds.
There are so many options for body kits, it might be possible to find some that are aerodynamically good, or that could be used as foundation for good shaping.
The Following User Says Thank You to fjasper For This Useful Post:
