Old 06-05-2012, 01:57 AM   #51 (permalink)
I've seen them they are well made. The hq is near my town..
THeir HID's are not bad power draw either...
Dave
If it has a motor its worth playing with.......
Old 06-19-2012, 08:21 PM   #52 (permalink)
Great job! Now you have me thinking!They make LED Emergency lighting. I got to "Procure" A couple and have some fun TOO!
Old 08-27-2012, 12:08 AM   #53 (permalink)
I bought up some 12v 10w "warm white" 3000-3500K color LED chips.
If you search "12v 10w warm white LED" on ebay you cant miss them.
See if I can build a set of kind to other drivers low beam head lights.
If I cant make them, aim them or partially cover them and make them easier on the eyes than most peoples factory headlights then plan B will be to make some stupid bright 20-30W (per head light) LED highbeams.
Old 09-01-2012, 10:48 AM   #54 (permalink)
There is now a wiki page for LED lights.
L.E.D conversion - EcoModder
California98Civic (01-15-2013)
Old 01-15-2013, 03:30 PM   #55 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Can someone post a picture of the led headlam light (low beam)shining down a road.....or 30 ft from a wall at the correct height?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-16-2013, 01:09 PM   #56 (permalink)
justme1969's Avatar
found this one super cheap
Our Most Powerful LED - 10 Watt Cool White 900 Lumen-Electronic Goldmine
the color index is quite high but the intensity is enough for a high beam unit.
I just thought I would dump it here for all the other techno geeks out there.
Old 12-16-2013, 02:20 PM   #57 (permalink)
...beats walking...
....but, does it require cryogenic cooling in order to achieve a reasonable use-life?
Old 12-16-2013, 03:24 PM   #58 (permalink)
justme1969's Avatar
yes heat sink is recomended.
I have had fair results using 2" x 3" 18 gage sheet metal base as sink.
Old 12-18-2013, 12:17 PM   #59 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
I'm waiting for a friend to get a set of these LED bulb replaceemnts and drivers... $115 is getting closer to affordable. Olympus Offroad
I recently picked up some 18w 1800 lumen 30* spot LED lamps, for the my Jeep and to put in the foglight locations on my Neon.
At about 20' and about 4' off the ground. These might be too bright for low beam use on the street though.
And just for informational purposes, the 6" lights in the first pic can fit slim digital ballasts for HIDs in the housing behind the lens. I've seen it done, and will likely do it to a pair as well. Offroad only, or, really dark deserted, no oncoming traffic in sight highways. The 6" lights are available at Harbor Freight for about $10 each and take a H3 bulb.
When it comes to Heroes, RENEGADES are mine!
Old 12-18-2013, 01:04 PM   #60 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
how many watt they take?
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
The Following User Says Thank You to echo-francis For This Useful Post:
ASV (01-10-2014)
