04-26-2010, 04:33 PM
#41 (permalink)
Pokémoderator
Ryland -
Originally Posted by Ryland
I'm miffed. I can't find a flasher unit in my fusebox(es). I think I'll have to ask saturnfans.com where it is.
CarloSW2
04-26-2010, 08:07 PM
#42 (permalink)
Can you hear/feel it when it is clicking?
04-26-2010, 09:36 PM
#43 (permalink)
Pokémoderator
Neil -
Yeah. This means it's in the console somewhere, right?
CarloSW2
04-27-2010, 03:12 AM
#44 (permalink)
aero guerrilla
Ha!! I can hear where the clicking noise comes from in my car: it's a tiny speaker under the steering column, while the flasher relay itself is supposedly either in the depths of the dashboard or under the fuse box in the engine compartment.
04-27-2010, 03:52 AM
#45 (permalink)
needs more cowbell
04-27-2010, 10:34 AM
#46 (permalink)
Pokémoderator
04-28-2010, 11:26 PM
#47 (permalink)
Okay, I got the new flasher units, and the rest of the LED bulbs today. The flashers now work perfectly with the old incandescent bulbs and with the LEDs:
Of course, the tabs on the flasher on the xD had to be clipped off to fit it -- they changed the mounting slightly...they are the two bits sticking out the back in this picture. The circuit board is completely different; though the two relays are still there. The IC chip is under the "U1" circle with epoxy on it, and there are four diodes, and a resistor on the top side.
05-09-2010, 09:39 PM
#48 (permalink)
I could guess some trimming had to be done. I see they generalized the relays for "japanese".. I may try it. I have no ecu, at least 3 miles less wiring than today.. I simply may try it out.
Heads up on the 194 bulbs.. they are skinnier at the socket than regular 194. I already took my license plate light aprt to squeeze in some tin foil on one side of the socket.
..and I took a slow ride in some hills. 2k rpm, tall gear..no pings. My theory that there was a diode needed in the ignition feeidng coil was a good one. The LEDs act as a diode..power on or off. It is a mystery. I will continue swap as well, with relay included.
05-12-2010, 12:44 AM
#49 (permalink)
Basjoos Wannabe
since 1 hp is 745 watts, does it take about 1 hp to make 745 watts of power? With that info in hand, you could see how many hp you're freeing by going to LEDs
RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
05-12-2010, 12:52 AM
#50 (permalink)
aero guerrilla
You have to take into account alternator efficiency, which is something like 50%-80%. So for each electrical watt saved you reduce the engine load by up to 2 watts.
The Following 3 Users Say Thank You to Piwoslaw For This Useful Post:
