Old 04-16-2015, 10:32 PM   #11 (permalink)
Panda - '92 Honda Civic VX
90 day: 53.55 mpg (US)
Charles II - '05 Honda Accord EX-L
90 day: 27.6 mpg (US)
Fitrari - '07 Honda Fit Sport
90 day: 36.4 mpg (US)
Well just filled up since the new O2 and lowered and only got 44mpg. Very disappointed with that considering I drive like a grandma. Feels like lean burn kicks in. Has that parachute behind me feeling when I try to accelerate in the proper rpm range. Idk what to do next. It's a 5 mpg gain from my last fill up. Back than It was 30 degrees and had a bad O2. Have gone through everything's maintence wise in the engine. Maybe could be the winter fuel giving that horrible mileage. Only thing I know is that my car needs an alignment since the coilover install.
LOW&SLOW
Build Thread:http://ecomodder.com/forum/showthrea...ild-31679.html
Old 04-17-2015, 10:04 AM   #12 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Nice progress. Hang in there, the mileage gains will come. The grille block will help a lot. I've found that with my own VX. I've had it off for about two weeks while I've re-worked my grilled/fog blocks in metal. Man, what a difference I've noticed. About 2 mpg's drop in mileage, and the car feels a good bit more unstable at speed without it.
I still have my original grill block and fog blocks, if you want them. PM me. Of course, my fog blocks are meant to work with OEM fogs, which I see you don't have. But lmk if you want my old set.
Thanks
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 04-17-2015, 07:57 PM   #13 (permalink)
Did some more work on the vx today. Work has been super slow this week. Replaced old grounds and added another one. Used 8g monster cable. Still need to replace the negative cable going to the battery. Also removed intake resonator and put holes in the filter box to pull hot air in. We will see if it helps at all.
LOW&SLOW
Old 04-19-2015, 04:28 PM   #14 (permalink)
Added the decal!
LOW&SLOW
Old 04-22-2015, 12:24 AM   #15 (permalink)
Finally swapped my summer tires on(kuhmo solus 175/70r13). Feels much better than the 155/80r13 Firestone winter forces I had on. Coasting speed has defiantly increased. Also my 60mph rpm dropped about 200rpm which puts me below 2k compared to my winter tires.
Performed an alignment as well. My rear toe adjusters are seized so not much I can do. Don't want to risk breaking the bolt going into the body. Got the fronts squared out atleast. LF was a real pain to move. Had to use my torch.
Going to do another fill up and scope out some coroplast tomorrow while I'm off. Hoping for atleast 50 mpg!
LOW&SLOW
Old 04-22-2015, 09:19 AM   #16 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Just noticed your thread. Has anyone recommended gauges to you. Our foot and our butt dyno cannot be calibrated well enough for optimal driving. For your OBD1 car, you should consider an MPGuino to accurately measure fuel use and a vacuum gauge to properly identify optimal engine load during acceleration. The OBD2 gauges most of us use are not compatible with your car.
Old 04-22-2015, 10:13 AM   #17 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Originally Posted by 92civicvx View Post
.......... Also have to wire up the mpguino. Been seriously slacking on that.
Originally Posted by California98Civic View Post
...... Has anyone recommended gauges to you. Our foot and our butt dyno cannot be calibrated well enough for optimal driving. For your OBD1 car, you should consider an MPGuino to accurately measure fuel use and a vacuum gauge to properly identify optimal engine load during acceleration. .....
from his first post.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 04-22-2015, 11:03 AM   #18 (permalink)
Thanks. Ya I have a mpguino just not hooked up yet. I hate wiring haha. As for a vacuum gauge waiting on my friend to bring a dual a-pillar gauge to work so I can see if it'll fit. Will have battery voltage and vacuum gauges installed. Also going to install a hand throttle, just need to pick up the kit from farm and fleet. Would love to have "cruise control" considering I go on a few road trips every summer to Missouri and tennesse.
LOW&SLOW
Old 04-22-2015, 01:07 PM   #19 (permalink)
Cyborg ECU
That sounds awesome. I missed the MPGuino mention, but I am glad to learn you're also after the vacuum gauge. One of the best hypermiling strategies are the "P&G" and "EOC" ... you accelerate at about 75% or maybe 80% load (vacuum gauge guided) and then cut the engine off at a pre-determined speed (injector cut off switch) then you gide back down 10 or 15 mph, clutch start gently and start the acceleration process again.
The gauges will pay for themselves in a few tanks--a few weeks or a few months. It's the most effective strategy, including better than most mods.
Some of us are more devoted to it as a standard strategy than others. With my car I use it heavily in city driving or freeway traffic. On good open road I cut the engine less often and do a lot more steady cruising, because I have the same super-tall gearing you have in your transmission (I swapped).
Looking foward to your progress.
Old 04-22-2015, 04:03 PM   #20 (permalink)
Finally back to getting 50+ mpg! Hopefully I can keep climbing up to the high 50s.
LOW&SLOW
civic vx
