Old 08-19-2011, 06:03 PM   #91 (permalink)
looking forward
Originally Posted by CigaR007 View Post
Spent upwards of 50 hours in order to complete both the upper and lower grille blocks.
Overall, I am quite pleased with them. Looking forward to a slightly better aerodynamics efficiency up front.
Please let us know how it all shook out.I have to believe that you'll see a difference.All the supporting evidence points in that direction.
Old 08-19-2011, 07:11 PM   #92 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Wow! That looks so good it's got to have a Toyota part number stamped on the back. Outstanding work.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
CigaR007 (08-21-2011)
Old 08-21-2011, 01:11 PM   #93 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Well, I guess this concludes the aerodynamic mods I had planned. I will try to come up with an A-B-A testing eventually.
Old 08-22-2011, 09:02 AM   #94 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
stealthy stylin' aerodynamic
And it shows a love of the car to have done it this way. I wonder if any of the manufacturers' engineers and stylists ever see these mods, and I wonder what they think. You have given yourself a subtle and unique design.
Old 09-03-2011, 02:29 AM   #95 (permalink)
CigaR007's Avatar
Averaged 58.7 MPG over 50 miles on Monday. Average speed was 45 MPH. No P&G involved, just DWB, DWL and steady throttle position.
I noticed that the cooling is somewhat efficient at lower speeds (lower than 30 MPH); temp was stable at 186F. At highway speeds (50-55 MPH) cooling is sufficient, but it sits a little bit higher at 190F. It's probably due to the angle of the opening of the lower grille.
The grille blocks are now held in place with a double-sided industrial strength tape. Figured I needed some extra peace of mind. I would never forgive myself if I had lost them on the road, not to mention the hazard to the other drivers.
Old 09-03-2011, 09:54 AM   #96 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
That looks extremely nice! The amount of time you spent on it shows as a very fine finished product.
Harbor Freight has a radiator comb for 5 bucks. With straighter fins, it should help the radiator be more efficient.
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
CigaR007 (09-07-2011)
Old 09-07-2011, 02:16 PM   #97 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Looks good I'm glad that you sloped the corners of the lower grill because I was wanting to suggest that as I looked over the build.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
The Following User Says Thank You to Phantom For This Useful Post:
Old 09-07-2011, 04:48 PM   #98 (permalink)
CigaR007's Avatar
@ Tango Charlie
Thanks for that link. I will definitely check it out.
@ Phantom
Yeah, I figured that airflow should be better with it. Still trying to tweak cooling for highway cruising (above 50 mph). I need to make a duct to redirect most of the incoming air to the radiator.
Old 09-07-2011, 04:59 PM   #99 (permalink)
Cyborg ECU
Ducting will save the day. Mine is pipe insulation, cardboard, and duct tape (someday I'll make version 2.1 with coroplast or something less vulnerable to water).
Old 09-12-2011, 08:23 AM   #100 (permalink)
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
Good Job and how come you do not add a lip to reduce more of the air under the car?
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
aero mod, grille block, toyota echo
