Old 06-03-2015, 08:06 PM   #1 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
lowered the civic today
I was able to get a set of tein s tech springs for $139 shipped which seemed like a great deal. I was looking for something to lower the car slightly without affecting ride quality. Daily driver status
I waited a few weeks to install them, got me thinking that my car at 300k miles probably had alot of spring sag to begin with and was sitting lower on the left side than the right.
Anyways I started with the passengers front and worked my way around the car
The tools. It should be noted that most bolts are 13 and 17mm on the suspension
At this point I'm not going to lie, the spring compressors are worthless tools but I did use them, at first.
The shock is able to slide out of the fork holding it to the lower control arm and you are able to slip it out after Un bolting the upper bolts
I'm skipping the pictures of using the spring compressors as I should mention I didn't use them after this first side
At this point I was worried my drop might be more than I bargained for
I am re using my stock shocks they seemed to be holding up fine
Good luck little buddy lol
I measured before and afters and the car was lowered half an inch at all 4 wheels. Once the springs settle a bit I'm figuring they will be close to a 1 inch drop
So my ride height didn't change drastically however I have noticed the car is more responsive to the road where as before it had a floating feeling to it
Cheers!
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
The Following 7 Users Say Thank You to Chrysler kid For This Useful Post:
92civicvx (06-04-2015), BabyDiesel (06-03-2015), digital rules (06-03-2015), dirtydave (06-04-2015), mcrews (06-04-2015), rumdog (06-04-2015), UltArc (06-03-2015)
Old 06-03-2015, 08:52 PM   #2 (permalink)
I cut mine and the cornering confidence improved dramatically.
Old 06-03-2015, 10:09 PM   #3 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
ride height looks good to me.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
Chrysler kid (06-04-2015)
Old 06-04-2015, 09:29 AM   #4 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
How's the alignment? Don't want the tires chewed up.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Old 06-04-2015, 09:33 AM   #5 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
looks loww! you make it look so easy!
The Following User Says Thank You to dirtydave For This Useful Post:
Old 06-04-2015, 10:35 AM   #6 (permalink)
When I had my MR2 I put Tein S-techs on them by getting a set of new shocks from someone who took them off because they didn't like the S-techs, so I got fresh shocks with it too for 200 and all I had to do was bolt them in. I think stiffer springs is a great thing, less floaty feeling and roll, and since you hit the bump stops less the ride can be quite comfortable.
The Following User Says Thank You to serialk11r For This Useful Post:
Old 06-04-2015, 01:34 PM   #7 (permalink)
RPM
RPM's Avatar
JF - '97 Honda Civic 1.5i LS VTEC (EK3)
90 day: 59.68 mpg (US)
Looks like a nice usable ride height.
Do you happen to have a picture of the rear Tein springs? I am curious. According to your picture the fronts use a truly progressive design unlike e.g. Eibach springs, which are two-stage. Wonder if the rear uses the same design?
The Following User Says Thank You to RPM For This Useful Post:
Old 06-04-2015, 02:57 PM   #8 (permalink)
5 pin sensor
You are correct sir, the factory springs on there are progressive so the more they compress the harder they get. The rears were the same way, I had to guess which springs out of the box were the fronts as they are only about an inch difference in height
The rears are the same way, so the springs should only get lower from here
Yeah the s techs are a pretty minimal drop my shocks seem to be doing fine. I didn't want to spend big money for a little drop
I have done many lowering springs and coilovers back in my day so I knew what I was getting in to. The rest of the shocks I removed the top nut on the car with a rag over the nut so the other 3 went quickly. In total I believe it was 4 hours including washing the car and shampooing the trunk carpet.
Shouldn't need an alignment yet, I'll give it a few weeks to get everything settled
OG lean burn member
My civic thread
The Following User Says Thank You to Chrysler kid For This Useful Post:
RPM (06-04-2015)
Old 06-04-2015, 03:05 PM   #9 (permalink)
5 pin sensor
My drivers side still appears to be lower not sure why.
I also changed the iridium plugs out for the factory ngk zr4f-11 plugs. Initial impression is that the car makes more power/torque but appears to lower the vacuum at idle. No real mileage put on them yet but even the clutch engages differently
OG lean burn member
My civic thread
Old 06-04-2015, 03:47 PM   #10 (permalink)
RPM
RPM's Avatar
Cool! It's a better design than the one used by Eibach and other manufacturers. Those tend to produce a lot of noise when the softer portion of the spring extends and then collapses all at once, e.g. when passing through a pothole.
