Old 05-27-2023, 01:11 PM   #701 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
But the issue is it is situation dependent on a case by case basis. Might work as planned, might not. I know I don't have enough compute power to predict it accurately.
It’s been done with a Prius and it broke records. The IONIQ and Prius are still similar overall shapes. The fast back hatch
ID:	33837   Click image for larger version
Old 05-27-2023, 02:04 PM   #702 (permalink)
IMHO. that's a good iner wall. The outer wall should be [for maximum benefit] like a Mercury Turnpike cruiser skirt that reaches up to the tail light.
Old 05-28-2023, 05:52 PM   #703 (permalink)
Phase's Avatar
First stretch of interstate. Averaging 61mpg at 70 mph
ID:	33843   Click image for larger version
Old 05-28-2023, 05:55 PM   #704 (permalink)
Phase's Avatar
Second stretch of interstate was 35 miles. Going from Portland to Seattle. Kept fluctuating in speed between 65-80 mph. Averaging mostly a little below 75mph. Got 67 mpg on that stretch.
Also for these numbers and previous numbers, there’s a 6-8 mph diagonal headwind. So even more impressive. Really curious to how tail wind numbers would be.
So far it seems like these flares are doing a bigger aero benefit than mirror removal or wheel skirts!
The Following 2 Users Say Thank You to Phase For This Useful Post:
freebeard (05-28-2023), Nathan jones (07-05-2023)
Old 05-28-2023, 06:44 PM   #705 (permalink)
Phase's Avatar
Last hour stretch or road. Wind died down. Slight corridor effect. Speed changing between 65-75mph. These numbers are insane. Seem too good to be true.
Old 05-30-2023, 11:09 AM   #706 (permalink)
'fastback'
Technically, neither Prius, nor IONIQ are 'fastbacks.'
As long as an uninterrupted, continuous curve is not presented in the design, by definition, 'fastback' cannot apply.
Both cars are close, but they're not quite there.
Lightyear Zero is an example of a proper fastback.
Old 05-30-2023, 01:30 PM   #707 (permalink)
Phase's Avatar
Any idea why these partial box cavity edge fins are working better than expected?
Old 05-30-2023, 02:39 PM   #708 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Has outside temperatures warmed significantly?. At least in Finland start to be summer...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (06-01-2023), freebeard (05-30-2023)
Old 05-30-2023, 04:07 PM   #709 (permalink)
Phase's Avatar
i mean the dash shows 65 degrees. real world was colder. my dash always reads 4-5 degrees above the weather app for some reason
Old 06-01-2023, 10:56 AM   #710 (permalink)
' better than expected'
If we have an 'expectation' of some realistic, isolated, drag-related performance enhancement, based upon some fluid mechanics mechanism, and then the observed performance happens to exceed what would be considered the upper limit, constrained by that specific mechanism itself, then it calls into question, either the viability of this chosen mechanism, our our interpretation of the observation attributed to it.
I looked ahead on your posts, and picked up on the talk about 'temperature.'
I'm guessing that this is being associated with air density?, and it's relation to drag; and that, perhaps you felt that at around 65F-to-60F, the air would be dense enough not to allow you to see the mpgs indicated, for the extended trailing edges added to the car?
If this jives with your thinking, then I'd want to offer some things to think about:
If you'll go online to 'Air Density Online,' and look at what their data requirements are for an air density calculation, in addition to the dry-bulb temperature, you'd also need to provide the:
* Raw barometric pressure reading
* Relative humidity ( RH )
* Elevation
* and technically, you'd also need to provide the latitude of the location where you're testing, as 'gravitational constant' is a myth ( you'll never see the accepted 32.2 feet per second/per second ) in either hemisphere on Earth, and local 'g', which is used in the air density calculation varies with latitude and should at least be recognized.
So why is this important? Here's a bona fide example, courtesy of Volkswagen AG:
When Volkswagen took their Jetta Hybrid to the Bonneville International Speedway, in 2013, to set a land speed record, the 'air temperature' was 46-F ( which might imply 'dense' air ).
However, when the barometric pressure of 25.9-inches of mercury, 14% relative-humidity, and 4,236-foot elevation were factored together, we saw that the air density (rho) had fallen to 0.0020565 slugs/ ft-cubed, 13.5% lower than 'Standard Air.'
I believe that this 'bookkeeping' complication is contributing to what you're experiencing.
If you had someone riding shotgun during your road tests, they could be online looking at National Weather Service and NOAA sites, plus calling AWOS at nearby airports to get dry-bulb temp., Dew Point, Barometer, and whether it's 'rising' 'steady', or 'falling', altimeter setting, density altitude data, and wind intensity and direction.
There's a half-dozen other things you're not accounting for as well. It's why car companies don't 'road test.' It's all done inside a computer.
It's tough not being a multi-millionaire.
