Old 06-04-2012, 02:19 PM   #11 (permalink)
7 Years Tire Experience, Presently an Engineering Student
The benefits of increasing the pressure in your tires is to minimize sidewall deflection when cornering and to minimize tread contact and therefore energy losses due to friction.
As dcb said the tire will not inflated beyond the diameter of the belts. The steel belts across the tread of the tire are meant to create a minimally flexible flat surface which the tread itself rides against. For that reason the tread area or crown of the tire is made of four or more plies (layers) of steel chords. The sidewall is predominantly nylon chords which allow it to flex under load. It is this combination of stiff surface and flexible sidewall which allows modern radial tires to get the longevity and performance which they do.
Increasing the air pressure (beyond MAX inflation listed on tire) to attempt to even out the wear in this situation will likely lead to a belt separation AKA a garbage tire.
I drive a '03 VW Golf TDI with 225/45R17 Toyo Versado LX on it. I run my pressure at approximately 40 PSI as I prefer the firmer ride, better handling and better economy. In the three years that I have had these tire all that I check for wear is overall evenness. You can't get better wear than that.
In summary, over-inflating your tires will even out wear to a point, but beyond that the benefits are negligible.
Old 06-04-2012, 03:00 PM   #12 (permalink)
KGM
Max advised PSI
I drive on European roads (more corners) on 195/65R15 tires with 2.8bar = 40PSI
/manufacturer's recommendation - 2.3bar/
I read in extreme economy mods' test in a car magazine (Autobild) that for fuel economy it is advisable to over-inflate max +0.5bar than manufacturer's recommendation -
so as not to lose from ride comfort and safety
and that max sidewall inflation or more will lead to a faster tyre sidewalls' wear - as said before me!
But strangewierding - my 17" set (exactly the same size - 225/45R17):
the tyre workshop advised me to inflate them directly to 2.8bar (40PSI) -
as a lower profile tyre needs a higher pressure to compensate ...
In my opinion on this size 40PSI is not over-inflation - but normal
Old 06-04-2012, 03:13 PM   #13 (permalink)
evilskillit's Avatar
The Spec - '03 Nissan Sentra SE-R Spec-V
90 day: 30.74 mpg (US)
It may depend on your tire. I have some 215/40/17 sport tires on my car rated at max 50psi. Running at just a couple of PSI below max they went bald in the middle first and after lowering the PSI down to around 40 I notice they have a slightly cupped shape now, like the diagrams at NTB show.
If I'd been driving harder, more often like most sport tire owners I might have worn down more of the edge and have more even wear. All things considered I probably increased the life of the tire because now at 40 it's going to wear on the edges faster than in the middle. Is this good for the tire, or safe? Not qualified to say. Have I saved anything on gas, maybe? Does the car feel like it rolls a lot better at 40psi and up? Definitely. Just my 2 cents.
Old 06-04-2012, 04:19 PM   #14 (permalink)
Tire Inflation Pressure Limits
What I meant by what I said is that you stay within the maximum pressure capacity of your tire. Lower profile tires tend to have a higher max pressure (44psi as opposed to 35psi). As such 40 psi would not be over-inflating for the 225's, but would be for the 195's. (Though in reality due to safety factors the tire COULD potentially run between 20-50% more air than what is listed; I do not recommend this)
Old 06-04-2012, 09:38 PM   #15 (permalink)
F8L
F8L's Avatar
F8L's 2012 Prius - '12 Toyota Prius Three with Solar Roof
90 day: 62.14 mpg (US)
Thank you for the data.
I performed a similar test with Goodyear Integritys (185/65/15) on my old Prius and tire wear was very even at up to 60psi.
Because mpg doesn't significantly increase with pressures higher than sidewall max I tend to stay around the 40-44psi range nowadays.
2012 Prius Three with Solar Roof - Blizzard Pearl w/dark gray interior: Prius Plug-In 15" Wheels | Michelin Energy Saver A/S 195/65/15 tires | TRD Lowering Springs | WeatherTech FloorLiners | Scangauge II | Morimoto/DDM HIDs 5000K | Clazzio Leather Seat Covers | Best Tank: 71.7mpg@702miles | Best Trip: 95.9mpg@233miles
Old 06-04-2012, 10:35 PM   #16 (permalink)
MaxHedrm's Avatar
Golf TDI - '10 Volkswagen Golf TDI
90 day: 37.69 mpg (US)
That's because it is the air that holds up the car, not the tire. So, the lower the profile, the less volume you have. The less volume the more pressure for the same amount of air. Heavy truck tires inflate even higher.
Driven: 2010 VW Golf TDI
Driven less: 2001 Audi TT Roadster (225)
Parked: 1982 VW Jetta Diesel
Old 06-04-2012, 11:09 PM   #17 (permalink)
This over-inflation is a VERY BAD IDEA and not worth the mileage savings.
These hi pressures causes less contact area on the road.
What about a panic stop?
What about a panic stop IN THE RAIN.
The damages to single / multiple cars involved is not worth it.
The life you end maybe... mine, someone you know, an innocent person or your own.
The Following User Says Thank You to Russjd For This Useful Post:
MaxHedrm (06-04-2012)
Old 06-04-2012, 11:26 PM   #18 (permalink)
WE0H's Avatar
Under inflation is a very bad idea. I run my tires at the max rated pressure molded into the sidewalls. Never had a tire failure, never had an accident, my car's handle way better than running them at Mr Donut pressures.
Mike
Old 06-04-2012, 11:39 PM   #19 (permalink)
F8L
F8L's Avatar
If you are going to make blanket statements such as the FUD above you should provide us with details and data that proves your point.
The Following 3 Users Say Thank You to F8L For This Useful Post:
NachtRitter (06-06-2012), PaleMelanesian (06-06-2012), WE0H (06-04-2012)
Old 06-05-2012, 12:36 AM   #20 (permalink)
Blanket Statement?
FUD?
Because you Never had a tire failure,
Because you Never had an accident,
what instrumentation are you using to determine "your car's handle way better"?
I go buy.... max tire contact = max braking, cornering (at "normal" speeds)
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Riddle Me This! Abnormal Tire Wear trebuchet03 General Efficiency Discussion 22 06-04-2012 10:46 PM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 06:47 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
