Old 12-27-2022, 10:43 PM   #21 (permalink)
IIRC the drill press was where I was headed when the mechanic said he could fix it or at least remove the lock cylinder.
The new switch was [apparently] soldered directly to the cable, whereas the 1990 model has push-on connectors.
But it's raining so I don't want to go outside and check.
“You belong to Universe” -- the voice in Bucky Fuller's head
Old 06-22-2024, 11:31 PM   #22 (permalink)
So [yesterday] I washed the XFi and aired up the tires. I just put 151 miles on it with a fill at the beginning and end.
43.3MPG. I tried to hold it down to 75. Driving around town, with the older tires, it will rattle an hum at 65, but after a half hour it wants to go 75 at the same throttle setting. After an hour I had to hold it back.
The inner tie rods ends will get replaced when the parts arrive, then I can get the front end aligned and some Continentals on that end. I had to replace the rear tires and they aligned the rear, but they won't touch the front until the tie rods ends are up to spec.
I entered it in a car show and won my class! The competition was two first gen Mustangs, a 1964 Ford station wagon, a (nice) 1948 Jeep pickup and a motorcycle. I took the Open class; the entry form said Open was for swathers and riding lawn mowers.
Isaac Zachary (07-05-2024)
Old 07-05-2024, 10:22 PM   #23 (permalink)
Growin a stash
Congrats! Pictures?
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following User Says Thank You to ME_Andy For This Useful Post:
freebeard (07-05-2024)
Old 07-05-2024, 10:53 PM   #24 (permalink)
Or it didn't happen?
I just got a $50 Polaroid digital camera, so it is possible again.
The wheels are currently red oxide primer, but I've got rattle cans to two-tone them; so any pictures would be before and after. I'll get on that.
I just had the four tie-rod ends and their boots replaced. No difference in how it drives, but now I can spend money on a front end alignment that will make no discernible difference.
Old 07-06-2024, 09:38 AM   #25 (permalink)
Hmmm never had front end work NOT make a noticeable difference. Couple of times it made life worse, and currently in the F250 I notice a tendency to wander, but in a very precise manner.
