Old 09-01-2013, 09:16 PM   #1 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Mis Fit Talon partial grill block
Finished my grill block today using 0.125" polycarbonate sheeting.
I first used 3M weld mask to mock up and a to make a stencil.
Then laid the stencil on the polycarbonate sheet and traced it out. Then I cut just the straight lines with a cut off wheel and finished the corners with a
80 grit 3M roloc 3" on.
Then I applied on the back side of the panels "SEM Bumper Coater" This is SEM's new version that has plastic adhesion promoter built into it.
This is picture removing the front side protective film off the sheeting. What you get is perfect gloss with no imperfections.
This picture is both sides done and ready to install.
Another picture of the bumper ready to go on the car.
Taken it for a test run in 94* F out on my test loop area.
Before picture.
Pressure Gradient Force
The Positive Side of the Number Line
Old 09-01-2013, 10:03 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
sweet!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
pgfpro (09-01-2013)
Old 09-01-2013, 10:20 PM   #3 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
I think your final production looks awesome, but being so shiny and brilliant kind of distracts from the rest of the car.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
The Following User Says Thank You to UltArc For This Useful Post:
pgfpro (09-01-2013)
Old 09-01-2013, 11:48 PM   #4 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Your absolutely right. This winter I'm going to paint the car black. It needs a paint job badly.
The Following User Says Thank You to pgfpro For This Useful Post:
mcrews (09-02-2013)
Old 09-03-2013, 12:23 PM   #5 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
any fe gains?
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 09-03-2013, 02:18 PM   #6 (permalink)
Would you kindly explain your steps in more detail for those of us pirates who do not do anything?
Old 09-03-2013, 03:51 PM   #7 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Originally Posted by deejaaa View Post
any fe gains?
On my "Instant Mileage" data-log I showed a 1 mpg increase @ 65mph.
I still need to do a full tank's worth though.
Old 09-03-2013, 05:23 PM   #8 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
1) The 3m Weld Mask is a one side sticky paper that's used for welding spark. I used it to simulate what it would look like on the bumper. Plus it doubles as a stencil. So you can stick it to the bumper and see what it looks like. Then I used 3/4" masking tape and ran it on the outline of the 3m Weld stencil so later I can match it up to drill the holes.
2) Then I laid the 3m weld mask stencil on on my poly carbonate sheet that measures 14' x 8'. I did a rough first cut with a cut off wheel and kept the corners straight at 90 degrees.
3) Then I used a 3" dia. 80 grit roloc to round the corners.
4) Then I put the poly carbonate grill covers in the 3/4" masking tape outline and pre drilled all the holes and installed them with #10 screws. Then I took them back off and pulled the back side of the protective film off to apply paint.
5) Then I painted three coat's of the SEM brand "Bumper Coater" on the back side. You can find this at your local Automotive Paint Jobber store.
6) Then I let that dry for a hour before removing the front side protective film coating. The film coating serves as a making when painting.
7) Re-installed them back onto the bumper with #10 screws.
After thinking about it you don't even need to take the bumper off.
Old 09-03-2013, 08:16 PM   #9 (permalink)
Heh. PGFPro, thanks for the clarification!
I decided to try to figure out what I could and when I posted, you had already clarified everything!
Is the Weld Mask relatively cheap? Is it like one big flame-resistant sticky note?
Did you use polycarbonate because you have fog\sports lights?
Bacon has those, but either they burned out, or I just do not know how to use them! I tried to figure out to cover them. I wanted it to look good, but since I did not know if I would notice a difference, I did not want to put much effort into it.
Duct tape looked terrible! It started peeling quickly, too!
Thanks again for explaining everything!
Old 09-03-2013, 11:20 PM   #10 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Weld mask is not very cheap. lol I had some extra at work so I just used it, but it just like a sticky note with full adhesive not just on the top.
I used the polycarbonate because I had some left over from a race car project i did a few years ago.
