Old 07-18-2019, 07:51 PM   #11 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
^ Some people live in environments where they do actually have to use brakes as part of their normal driving. For them, deleting the IMA does not have benefits that outweigh the cons.
Otherwise though, I agree. Driving with load was always far more successful for me than pulse and glide.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
Gasoline Fumes (07-19-2019), mpg_numbers_guy (07-19-2019), Xist (12-10-2019)
Old 07-19-2019, 12:45 AM   #12 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I was getting around 80 MPG in a borrowed 2001 Insight a few years ago. That was on 165/65-14 snow tires in the winter! No mods other than tire pressure and a temporary clutch switch. I really need to add a clutch switch to mine, the nearly constant assist seems so unnecessary and inefficient. And I need a kill switch.
My wrong tires are 175/65-14. Special-ordered for the previous owner and still the wrong size! I have them at 50 PSI. The large cracks in them keep me from going higher!
I don't brake enough to get a useful amount of regen.
I'm getting tempted to sell the IMA battery. It seems to be working flawlessly, which might be the ideal time to remove it! Plus it would more than pay for the car.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 07-19-2019, 12:59 AM   #13 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
If you don't brake enough to get regen, and you aren't stopping the assist through a clutch mod or disabling/removing the battery, your car will almost always be in forced regen mode, which can cost you anywhere from 10-25 MPG in my experience. Forced charging isn't as subtle in the Insight as it is in the Prius.
Have you been able to detect lean burn yet? The IMA will almost always be assisting when not in lean burn, and doesn't assist when in lean burn.
If you switch off the battery and unplug the two connectors on the BCM, you can drive it without the battery functions and see if removing the forced regen improves your mileage to test without removing the battery. You'll have to key off to EOC since autostop will be gone, and acceleration will be slow until you remove the battery, which helps some.
I'm also trying to sell my hybrid battery as well, but haven't had any great luck yet. Probably because I've listed it a bit too high for now.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Old 07-19-2019, 01:35 AM   #14 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I need to pay more attention to when it's in lean burn. I'd like a light for that!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 07-19-2019, 06:40 PM   #15 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
81.7 MPG with the IMA off.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Daox (07-19-2019)
Old 07-20-2019, 01:21 AM   #16 (permalink)
Team Mazda
If you have a Scangauge or the Torque app, watching the O2 sensor voltages will indicate lean burn. One of the sensors reads 0v when in lean burn, and >0v when not in lean burn.
You can also tell by engine load vs mpg, which is what I do. If you drive the car enough, you can tell just by the instrumentation.
Note that in order to get lean burn with the battery disabled your hybrid battery must be at least 20% charged if a 2000, and at least 50% charged if a 2006. Otherwise the car doesn't get lean burn. I learned the hard way once and got "poor" (if it can even be called poor) mpg on a highway trip. I wondered for the whole day why I wasn't getting lean burn. It was because I had reset the 12V, so the car thought the battery was empty on my IMA disable, so I didn't get lean burn until I let the car recalibrate and display the battery's correct charge level.
Sounds like that might be your issue then. Even a healthy battery has some slight background charge, and with limited brake use, forced charge is the only way the battery can charge.
IMA battery = faster acceleration = more power, and with limited braking for regen, = forced recharge = power robbing = lower fuel economy.
Gasoline Fumes (07-20-2019)
Old 07-20-2019, 10:29 AM   #17 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Looks like the previous owner had another one stashed there ... behind all the others in the first pic
Old 07-20-2019, 11:34 AM   #18 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
No, that's my other Insight! I have too many cars!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
euromodder (07-21-2019)
Old 07-30-2019, 08:46 PM   #19 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
97.0
Clutch switch helps a lot!
Also on old RE92s now. I think I filled them to 55 PSI.
No other mods yet.
Missing all front under panels, mystery oil from 3+ years ago, mystery spark plugs, EGR probably plugged.
I had to giddyup for a bit when a State Trooper was behind me!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 3 Users Say Thank You to Gasoline Fumes For This Useful Post:
Ecky (08-02-2019), mpg_numbers_guy (07-30-2019), Xist (12-10-2019)
Old 07-30-2019, 11:32 PM   #20 (permalink)
Team Mazda
There ya go! Great mileage and still tons of low hanging fruit to go. With a few mods I see myself having to play second to you in the Insight fuel logs here on Ecomodder very shortly!
Gasoline Fumes (07-31-2019)
