Oh, thrilled with his build, but...soon after I picked up my 3kw ebike motor, he built a 3kw plywood ebike. Then around the time I got the 9kw controller, he put up his video of his electric motorcycle build. Now I mention trike in my previous post and youtube must have been listening, and recommended his trike build from the summer. Not sure how I missed it. He needs to slow down. He's hurting my feelings. (If I had any). |
02-01-2021, 04:23 PM | #36 (permalink) |
Firefly EV - '98 Pontiac Firefly EV 90 day: 107.65 mpg (US) Little Boy Blue - '05 Toyota Echo 90 day: 33.35 mpg (US) BlueZ - '19 Nissan 370Z Sport 90 day: 17.19 mpg (US) Thanks: 75
Tried taking it apart, no dice. Had to buy a 27mm socket to get the nut off the pulley. Odd size.
22mm keyed front shaft: 14/12mm tail shaft: Thought I'd lost the key...spent 10 minutes looking for it on the floor, only to find it hiding on my bench under the motor. No photo, but good to note...the 4 big bolts clamping the two halfs of the unit together are in a lovely square, making it 6" square in the middle...nice and tidy for use as mounting points. And on a side note, I had a regular alternator pulley on my bench, and it just happened to be the same 17mm that both my treadmill motors use. Nice fit: Can probably turn it around and make it closer to the body of the motor. |
02-21-2021, 02:59 PM | #37 (permalink) |
Another one arrived.
First thing I noticed was the tag saying it was from a 2015 model, and the larger plug on it. It reminded me that I read, somewhere along the way, that in 2013, they upped the power output. I eventually tracked down a snippit that said they were 8.5kw to begin with, but changed in 2013 (presumably for '14 model year?) to 10.5kw. Interesting. For comparison: Thicker wires too: Nothing looks different inside: Thought they just changed the connector, but they had to widen the casting a bit to make it fit: Otherwise, they seem identical. Same thickness of windings and number of strands, voltage output spinning at the same speed is identical, pulley and coolant tubes are the same size and they weigh exactly the same(at least on a scale that only does 1/10 of a pound increments). Hmm. Interesting. Guess they decided the internals were a bit higher rated than the externals? Or just decided it would be cheaper to push it to it's limit rather than redesign the whole thing. The short bus-bars(the solid metal the wires are bolted to) on the "8.5kw" are a nice shiny silvery color: (They're reflecting what's around them - the gold of the bolts to the right, the black of the insulator to the left.) Whereas the "10.5kw" one, the bus-bars have that lovely dark rainbow effect caused by heat: Maybe they changed their generation strategy for fuel efficiency, opting for more amps at less volts? Lower engine speed = more efficient for low power output, right? right. Your guess is as good as mine. Part number changed, though it's close: The junk yards seem to think they're the same. Maybe they send the plugs with them for a reason(though it's probably just because it's quicker to cut them out). With the plug, you could hook a later one up to an earlier model with no bother. Digging around, trying to find anything solid on the kW rating, I found a snippet that explained the hybrid starter-generator (HSG) as being a "IPMSM" - an "Interior" Permanent Magnet Synchronous Motor...well, that explains a lot(or at least gives rise to theories that make sense) . Like...the low level of cogging...why the brushless control found it easy to pick up the back EMF to determine timing...and presumably why there was such a large difference between the input voltage on the controller and the rectified voltage output. (Square wave vs sine wave) As it's a PMSM, it can supposedly reach 95% efficiency. I suppose I could look at so-called sine-wave controllers...there's a 3kw, 72v one for under a hundred bucks on Ali...but if I ever want to see full potential out of these things, I need to look at Paul's 3-phase, vector controller... That sounds like too much work. |
The Following User Says Thank You to Stubby79 For This Useful Post: | freebeard (02-21-2021) |
03-07-2021, 04:19 PM | #38 (permalink) | |
Vector control = field-oriented control = field weakening in a reluctance motor. Since these motors are a PM/Reluctance hybrid, it works on them, raising the rpm...while retaining the low-end grunt(torque) of a PM motor. Super neat-o! (So much for sep-ex field weakening). When I read "Interior Permanent Magnet" I was like..."Why???". Seemed at first thought it would make for weaker magnetism than having the magnets right on the outside of the rotor, second thought was simply to be able to contain the magnets safely at stupid high RPM. I wasn't considering the iron - wasn't even considering what it was made out of, to be honest - and how it becomes magnetized when in a magnetic field. Duh! Didn't realize it was reluctance. I knew what reluctance was, electrically, didn't put it in context with magnetism and iron in a motor. Yeesh. Only because of youtube that I do now: (gets really interesting at 9:38) Wasn't sure the HSG was the same. Makes sense that it would be, cuz this thing has to be able to hit 16000rpm...and if there was no field weakening, then you'd end up with a stupid high back EMF voltage, which you could compensate for, I suppose, and you'd not be able to feed any power in to it once it got above battery (or voltage multiplier) voltage, yet everyone (auto makers) claims their hybrid setups make power at higher RPM. Assumed induction...should have clued in then. Anyway, back on topic...wasn't sure, half the reason I wanted to pull one of these HSG apart, but they don't come apart easily...but you can just barely see down inside through the back: First shot you can't really see the laminations -- dang it, another word to add to Firefox's "dictionary"; stop correcting me when I'm not wrong! -- but look at how tiny those stator (another word!) coils are! The whole rotating field makes more sense when you have a lot more coils...as does the smoothness of the motor. Second shot, you can just make them out. The gnarled-look to the metal on the rotor right beneath the coils. Dang hard to take a picture of even that much, but you can see it with the naked eye. Laminations, between - presumably two - mirror-bright (you can see the reflection of the coils on it) end plates, which are presumably there to compress the laminations tight. So, yes, we have laminations, so we have reluctance and everything that goes with it. The thickness (thinness?) of the copper windings makes sense as well, seeing how small said coils are. Why others cram bars through there instead of wire also makes sense, as small as they are. The whole BLDC bit has tainted my assumptions of what it would be like inside quite a bit. Considerably fewer - therefore larger - coils, and equally large magnets. Not a lot of difference between the one in my insight and the ones on my ebikes. While similar, this is definitely different. A lot more switching going on to get higher speeds with more coils...then again, R/C motors spin at stupid high speeds, so not much reason for these not to translate that in to less speed and more torque. Speaking of BLDC motors...which are fed via square-wave (or at least trapezoidal) rather than sine-wave...I would have thought that a magnet going past a coil would naturally result in a a sine-wave, but supposedly not...why not? is it trying to be a sine-wave, only saturation is cutting the rounded top off of it? That's what comes to mind...trapezoid = cut-off sine wave. Just a thought... Yes, I use this thread as a sounding board. Helps me put my thoughts together, trying to explain them...often find details I've missed or assumed inside my head along the way. Almost forgot...the whole synchronous bit about how the rotor follows the rotating field and stays in sync with it...and how using one of these as a generator creates a nice 3-phase sine wave output...well...that means you could use one to drive another one -- right up until it you hit breakdown torque (where the motor slips out of sync with the input) at least. You couldn't start the motor with any load that way, but once it got going, if you didn't put so much load on it that it would fall out of sync, you'd be ok. It would be quite a mess if it did, mind you...anyway, it seemed like a potential way to transmit power electrically, rather than mechanically, if you had reason to. You could use a brushless controller to get it(both actually) started with a load on it, even, then switch over to driving one of them mechanically to drive the other one electrically. I tested it, using my cordless drill again. It started the driven motor after an initial twitch as it synchronized, so no-load starting is fine. Hold the driven motor from spinning and it just twitches in your hand. With the drill on low speed, I could stop it spinning by hand, despite having more torque on the driver motor. With the drill on high speed, it was the drill that gave out instead (the BMS on the battery cut out from over-current). That was rather as expected. No starting torque, but the faster it went, the more torque it could provide. I assume this is due to the peak voltage output being higher, therefore able to make a stronger push/pull on the coils. I'm really left wondering what the breakdown torque would be at high speeds. I would hazard a guess that if it was being fed the full 270v, it would be dang hard to stop it...as in you might see that 10kw without much bother. Or it might fall flat on it's face. Going to have to experiment, get it up to a decent speed with plenty of power behind it and see if I can stop it turning. That treadmill motor with an alternator pulley is looking like a good place to start to spin the driver motor... Could have it's uses, if it works...serial hybrid on something like a motorcycle...battery/controller for in-town speeds, engine driving a motor as a generator for higher speeds. Nah, it will probably fall flat on it's face and blow up first. Another thought...so, the motor synchronizes with the speed of the input wave form. So if I feed it off of 60hz 3-phase "mains", it should work...but...but...but...it's not going to turn very fast. If it doesn't turn very fast, the back EMF is not going to equal anything near the input...but it can't go faster than the 60hz will let it...is it just going to create an awful lot of heat? You'd be dissipating whatever the voltage difference between the two is, through the coils...so yeah, I think it would just get very angry and overheat. HMM... I'm OK with that. "For science!" BOOM! Last edited by Stubby79; 03-07-2021 at 05:04 PM.. |
03-07-2021, 07:03 PM | #39 (permalink) |
I didn't watch the whole video, but I notice they eventually admit Toyota did it first.
Back when I was trying to understand this, I found the Texas Instruments Youtube videos were the most helpful, but I don't remember which one specifically. If you watch these; https://www.youtube.com/results?sear...iented+control ...and one uses an analogy of watching a target while being on or off a merry-go-round, then that's the one. The first one is good.
. .Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster ____________________ . ."We're deeply sorry." -- Pfizer |
The Following User Says Thank You to freebeard For This Useful Post: | Stubby79 (03-08-2021) |
