Old 07-29-2020, 07:02 PM   #131 (permalink)
Da Vinci - '91 Geo Metro Spaceship
90 day: 47.82 mpg (US)
V8BARGE - '11 Ford Crown Victoria LX
90 day: 15.15 mpg (US)
The Dakooter - '99 Dodge Dakota 4x4(FWD only)
90 day: 8.82 mpg (US)
Rebuilt IAC. Responds to electrical loads nicely but still idle away fast. Must be a vacuum leak or a bad engine coolant sensor.
The Following User Says Thank You to Trekintosh For This Useful Post:
Xist (07-29-2020)
Old 07-29-2020, 07:13 PM   #132 (permalink)
90 day: 30.54 mpg (US)
I once made a smoke machine to test vacuum leaks.
The Following 2 Users Say Thank You to Xist For This Useful Post:
California98Civic (07-29-2020), Trekintosh (07-29-2020)
Old 07-29-2020, 07:14 PM   #133 (permalink)
It’s a good idea but I don’t wanna. I’m just going to use the time honored “spray throttle body cleaner around until it drops rpm.”
Old 07-29-2020, 07:16 PM   #134 (permalink)
Be sure to light some candles to appease those temperamental mechanical spirits.
Fat Charlie (07-29-2020)
Old 07-29-2020, 11:54 PM   #135 (permalink)
Welp, mostly figured out the fast idle. Not gonna go into detail, it was mainly just unplugged vacuum ports.
Did a compression test... not good. Apparently metros are toast anywhere below 156psi. I got 91, 126, 96. Ugh, gonna need an engine rebuild. I might be able to limp it through smog, we’ll see.
Xist (07-30-2020)
Old 07-31-2020, 04:47 PM   #136 (permalink)
Got yelled at on the metro forum for posting the mileage I got on my first sort of wrong octane tank (around 50-55mpg).
Old 07-31-2020, 04:58 PM   #137 (permalink)
Too much or too little
"We're deeply sorry." -- Pfizer
Old 07-31-2020, 05:06 PM   #138 (permalink)
https://cdn.discordapp.com/attachmen...944/image0.png
The Following 2 Users Say Thank You to Trekintosh For This Useful Post:
Fat Charlie (08-10-2020), freebeard (07-31-2020)
Old 07-31-2020, 05:54 PM   #139 (permalink)
Low compression, but your car has a ridiculous amount of modifications!
The friendly guys here MPG-shamed me for only averaging 44 MPG in my Civic. It turned out that I had low compression. When I fix the heater core I will see if replacing the head gasket happened to improve the compression.
Old 07-31-2020, 08:36 PM   #140 (permalink)
"End of topic"
Does that get bumped with each post [EOM] or did they put the kibosh on the subject?
