07-29-2020, 07:02 PM
#131 (permalink)
Rebuilt IAC. Responds to electrical loads nicely but still idle away fast. Must be a vacuum leak or a bad engine coolant sensor.
The Following User Says Thank You to Trekintosh For This Useful Post:
07-29-2020, 07:13 PM
#132 (permalink)
I once made a smoke machine to test vacuum leaks.
The Following 2 Users Say Thank You to Xist For This Useful Post:
07-29-2020, 07:14 PM
#133 (permalink)
It’s a good idea but I don’t wanna. I’m just going to use the time honored “spray throttle body cleaner around until it drops rpm.”
07-29-2020, 07:16 PM
#134 (permalink)
Be sure to light some candles to appease those temperamental mechanical spirits.
07-29-2020, 11:54 PM
#135 (permalink)
Welp, mostly figured out the fast idle. Not gonna go into detail, it was mainly just unplugged vacuum ports.
Did a compression test... not good. Apparently metros are toast anywhere below 156psi. I got 91, 126, 96. Ugh, gonna need an engine rebuild. I might be able to limp it through smog, we’ll see.
07-31-2020, 04:47 PM
#136 (permalink)
Got yelled at on the metro forum for posting the mileage I got on my first sort of wrong octane tank (around 50-55mpg).
07-31-2020, 04:58 PM
#137 (permalink)
Too much or too little
07-31-2020, 05:06 PM
#138 (permalink)
https://cdn.discordapp.com/attachmen...944/image0.png
The Following 2 Users Say Thank You to Trekintosh For This Useful Post:
07-31-2020, 05:54 PM
#139 (permalink)
Low compression, but your car has a ridiculous amount of modifications!
The friendly guys here MPG-shamed me for only averaging 44 MPG in my Civic. It turned out that I had low compression. When I fix the heater core I will see if replacing the head gasket happened to improve the compression.
07-31-2020, 08:36 PM
#140 (permalink)
"End of topic"
Does that get bumped with each post [EOM] or did they put the kibosh on the subject?
