Old 03-05-2012, 04:56 PM   #11 (permalink)
I was looking at oil less air compressors online and found this high pressure unit.
Makita USA - Tool Details - AC310H
400 psi working pressure and less than $700.
I would also imagine that certain refridgeration compressors would work well and could probably be found for free.
Old 03-05-2012, 06:46 PM   #12 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
400psi in the application I am looking at would give me roughly 8 miles range, I am hoping for a minimum of 20 miles on CNG via at home compression.
The key is finding a used unit already intended for h2 or welding applications.
Old 03-05-2012, 07:47 PM   #13 (permalink)
Is that 400psi with roughly 8 mile range ANG or CNG ?
Quoted from-
http://www1.eere.energy.gov/cleancit...11_pfeifer.pdf
At 35 bar and 22 °C, ANG volumetric storage capacity is 5 times higher than CNG
Old 03-05-2012, 08:16 PM   #14 (permalink)
rmay635703's Avatar
Quoted from-
Given the ANG tanks I can buy, I would say either, the ang tank would just be a little smaller. (aka there is only one company in the us selling ang tanks and they are only a little shy of a gallon)
Old 03-06-2012, 04:45 AM   #15 (permalink)
Could you post a link for ang tank supplier ?
Old 03-06-2012, 09:31 AM   #16 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Can't vouch for their reliability, and they likely won't come very cheap, but take a look at Holugt or Motor Jikov products.
I wouldn't go cheap on compressor and tanks for CNG - or any other pressurized, flammable gas for that matter.
They give 2900 to 3600 psi though - 200 to 250 bar - so the tanks must be able to hold that much pressure.
Old 03-06-2012, 01:24 PM   #17 (permalink)
rmay635703's Avatar
http://www.gas-tec.com/images/PDFs/ref60_1.pdf
Old 03-06-2012, 01:27 PM   #18 (permalink)
rmay635703's Avatar
The tanks hold 3600PSI since I have a real stock CNG car lined up (but may not buy)
I am not interested in compressing the gas to 3600psi at home, I would prefer 1000psi or so due to speed, safety, reliability, cost and the potential of buying used.
All 3600psi pumps that would fit in my home are
1. expensive
2. Unreliable
3. not rebuildable.
4. High cost per gallon pumped.
Lower pressure units are more efficient per gallon pumped, generally rebuildable and much more reliable, sadly I don't know what brands are best for flammable materials.
AKA afterall, somebody is compressing the hydrogen, nitrogen, and natural gas welding tanks?
Old 03-07-2012, 10:54 AM   #19 (permalink)
Here's another page from the same website that has the refueler with the tanks listed separately.
purchase
I haven't found any other commerical tanks available. However, I don't believe
it would be that difficult to DIY.
Old 03-07-2012, 12:26 PM   #20 (permalink)
http://www.borukaynak.com/cylinder_1.pdf hera are dimensions of them.
So - 130 cubic foot of ng is 4.5 cubic metre or more than gallon of gasoline equivalent.
Gasoline gallon equivalent - Wikipedia, the free encyclopedia
Only one minus - not dot aprooved,
