Old 06-18-2008, 01:13 AM   #11 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by SVOboy View Post
If you have an HF tranny revs should be that much of an issue. Mine is at ~2000 at 62 mph with stock tires.
Mine is at 2300-2400 ish at 60mph.. but i have a first gen HF.. they seem to be diffrent than the 2nd gen
Old 06-18-2008, 01:20 AM   #12 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Ah, yes, forgot about that,
Old 06-18-2008, 01:21 AM   #13 (permalink)
Dartmouth 2010
SVOboy's Avatar
I wonder if you could buy an EF HF 5th gear and throw it in your tranny....
Old 06-18-2008, 04:36 AM   #14 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
I found that SATURN steelies 15" fit HONDA 4x100. So do mazda MIATA rims -forgot what yrs. not sure of the width on any of them tho. I'm sellin 2 of my VX rims (no tires) for $160 , made by enkei (((woot))). or unless u want 15" alloys anything from the INTEGRA would fit on your CRX.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 06-18-2008, 08:43 AM   #15 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
my 1985 crx hf is around 2,000rpm at 65mph, I just put a different tranny in it before selling it to my brother because it had the wrong one in it when I got it, also if you get one from a state with moutons it will have different gearing as well.
the stock rims on an hf should be 13" 4.5" wide steel rims, that are 12.5 pounds same as the civic cx has, stock civic steel rims are 5" wide and weigh 15 pounds or so, I would say going with a 155/80 R13 tire is the way to go unless you can find some 145 R13 tires (no /number indicates that they are a 85 aspect ratio), bu that is going to give you good traction, light weight and a tall tire, stock tires on the crx hf are often 165/70 R13, same as the civic vx.
Old 06-18-2008, 05:31 PM   #16 (permalink)
ttoyoda's Avatar
ebacherville
Watch out for the different size center holes as well as the wheel offset. I know the wheel is "theoretically" supposed to center itself due to the tapered seats on the lug nuts, but still... The offset will make the wheels stick out to the sides more or less, and change the loads on the wheel bearings.
Old 06-18-2008, 06:44 PM   #17 (permalink)
Veggiedynamics
Originally Posted by ttoyoda View Post
ebacherville
yeah thats why i want to source them at a local junk yard.. so i can try before i buy..lol
Old 06-18-2008, 06:48 PM   #18 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
mid 80's 3 series BMW's had 4x100mm..
Old 06-18-2008, 06:57 PM   #19 (permalink)
EcoModding Minded
Chris D.'s Avatar
go here
http://www.wheelweights.net/
choose alpha..
scroll down to honda..
The Honda Civic HX wheels get my vote at 14x5.5 @ 11.8lbs a piece..
these usually come in silver..
Old 06-18-2008, 07:12 PM   #20 (permalink)
Beater Deluxe v2.0 - '89 Honda Civic DX
90 day: 44.68 mpg (US)
Send a message via AIM to Joseph Davis
If it's a stock HF, going with a taller gear will net nothing or drop engine below it's sweet spot in efficiency.
I'm going with a .702 ratio 5th out of an OBD2 car for my 88 Civic DX's new gearbox... it's not quite HF 5th gear territory, but I've been netting almost 40 mpg on a highway cruise from the stock 92-95 DX drivetrain in it. With the new engine I'm hoping to push 50 mpg with no aero work.
FYI, Chris, VX rims look exactly like HX, come in 13X4.5, weight less than HX, and do not command the absurd resale value of HX rims.
Also, i hear the fugly Civic Hybrid rims weigh very little, IIRC they are a 15X5.5-6 rim.
Which CRX? seanof30306 EcoModding Central 8 02-10-2009 05:52 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
non-op '85 CRX, or '91 civic hatchback SirKeats EcoModding Central 1 05-16-2008 04:21 PM
CRX HF transmission swap paulwelkins EcoModding Central 2 02-02-2008 05:52 AM
