Old 07-16-2010, 07:21 AM   #11 (permalink)
I agree with bike4miles, that is very clean and well done!
Old 10-03-2010, 10:25 PM   #12 (permalink)
4ringcircus's Avatar
Ford Ranger - '97 Ford Ranger XLT 4x4
90 day: 21.28 mpg (US)
Wow, that looks good. I love the belly pan idea because it is so subtle, no one know's you've done it. I think I will start a belly pan for my Ranger soon.
Old 08-19-2011, 01:39 AM   #13 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Thought I would give a long term update on this project. The pan made it through a Canadian winter in fairly good shape. I almost took out the front pan on a large lump of ice in a parking lot, but it was repairable without too much trouble. My front corner pans and front air dam are getting a little beat up. My wife has run them into the parking lot curbs several times now, and they haven't like it. I think that road noise has increased a little since I installed them as well.
As for mileage improvement, I am quite certain that the project was a success. I don't do a lot of driving on the highway, but when I do, mileage is consistently better than before. This summer is the first time I have done GPS corrections for speed and distance and found I have to reduce the mileage numbers by 1.8%. Even so, Scanguage has been showing 33mpg at 65mph on calm days and up to 35mph at 55mph. That's a good 2mpg better than what it was without it. I did build a rear pan as well before our vacation trip last week. It may have helped a little, but not enough to notice. I removed it when we got home though. I made it in a hurry and not very well but I still may revise it and try it again.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
The Following User Says Thank You to puddleglum For This Useful Post:
aerohead (08-19-2011)
Old 09-28-2011, 12:55 AM   #14 (permalink)
puddleglum's Avatar
So, I have decided to revise my rear pan and see if I can make it a little more efficient. I have a couple of questions though. First, my rear bumper cover is quite rounded at the bottom. Might there be some benefit in extending the pan past the bottom edge of the bumper cover? I can easily go 3" without going past the bumper. Is that short distance likely to help enough to notice? Second, is it worthwhile building strakes on the outside edges? I was thinking of putting a couple in line with the inside edges of the tires.
Old 09-28-2011, 01:04 AM   #15 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Just finished looking through your photo album.. that's some impressive work !
Old 09-28-2011, 01:57 AM   #16 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Very nice work.
I would say extending the belly pan out past the bumper couldn't hurt and it would eliminate the possibility of the airflow detaching sloppily on the bumper curvature.
Old 10-04-2011, 12:27 AM   #17 (permalink)
Reloadwin's Avatar
Silver Prius - '08 Toyota Prius
90 day: 46.37 mpg (US)
Looks Good keep it up.
Old 10-05-2011, 01:10 AM   #18 (permalink)
puddleglum's Avatar
So my rear pans are almost done, finally. I never seem to do anything the easy way so, as usual, they are pretty complicated and took a lot of time. Hopefully they help a little more than my first attempt. I needed to have access to my spare tire (mounts under the car) so I made a three piece rear pan. I also am concerned about covering the exhaust, but I'm hoping that the vent holes will allow enough cooling without ruining the airflow too much. Here are a few pics of the work in progress.
The three piece pan and a pan to cover the exhaust pipe behind the catalytic converter.
I decided to ad small strakes (is that the right word?) to try and direct the air better.
I had to fill and paint the back of the pans since they will show.
I have a 200 mile trip on the weekend, so it will be a good test run.
TOOQIKK (10-06-2011)
Old 10-05-2011, 01:33 AM   #19 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
very very nice.
Pack a box of 'fast fix' supplies.
Also, think about taking a couple of foot long 2x6. Thst way when you get up in the morning you can drive up on the real quick and take a quick look underneath w/ uot haveing to get the jack uot
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-05-2011, 07:29 AM   #20 (permalink)
OurInsight - '06 Honda Insight
Very nice work.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
2010 Prius belly pan set up ALS Aerodynamics 12 09-10-2009 06:27 PM
Started on a belly pan brucey Aerodynamics 3 02-03-2009 08:14 AM
