Old 06-27-2022, 01:44 AM   #111 (permalink)
Yea, don't use a drill press! I very recently tried that. I can't seem to find the drill chuck for my lathe, so I decided to try making Magic Spark Plugs with the drill press. Neither drill bit hit the center target. The result was a botched plug. Emissions showed I was better off with the normal plug.
I don't know what to say, other than the only success I've had was using a lathe to keep the holes centered. If you're a better machinist than me, maybe you can do a much better job than I did.
Recovering Gasaholic
The Following User Says Thank You to mpgmike For This Useful Post:
freebeard (06-27-2022)
Old 06-28-2022, 09:49 AM   #112 (permalink)
You could use a drill press if you can dimple the electrode to provide a start point for the drill or sharpen the angle of the point (difficult on a .060 drill bit). Dimpling without breaking the electrode is going to be tough.
Would be the same effect by increasing gap, system voltage and indexing the plugs
Old 06-28-2022, 12:06 PM   #113 (permalink)
I'd let go of the idea, but a Dremel-sized ball mill would give a cupped rather than cone shape.
Now I'm not sure why the 'torch' extends beyond the electrode.
Old 06-28-2022, 02:21 PM   #114 (permalink)
Here are some progression pics. I put feeler gauges between the electrodes to keep from damaging the outer electrode strap so I could dimple a mark. If you're better at this stuff than me, you may be able to do a better job. My eyesight isn't what it used to be.
Old 06-28-2022, 02:22 PM   #115 (permalink)
It only does that after igniting the first puff of fuel. As that fuel burns, it becomes the blow torch.
freebeard (06-28-2022)
Old 06-28-2022, 06:15 PM   #116 (permalink)
EDM
Electrical Discharge Machining (EDM).
It will make short work of this.
Old 06-28-2022, 06:41 PM   #117 (permalink)
I'm not familiar with that term. Could you explain, perhaps provide a link?
Old 06-28-2022, 08:03 PM   #118 (permalink)
hackaday.com/2017/03/08/diy-barrel-rifling-with-3d-printed-help/
mpgmike (06-28-2022)
Old 06-28-2022, 08:52 PM   #119 (permalink)
Electronic Dance Music will be at the top of your search, cuz . . .
This is what you should be looking for.
The Following 2 Users Say Thank You to RustyLugNut For This Useful Post:
freebeard (06-28-2022), pgfpro (06-28-2022)
Old 06-29-2022, 12:42 AM   #120 (permalink)
Wow! I'm blown away! I've seen stuff apparently made with this process, but had no knowledge of the actual process itself. Thank you 2 folks for the quick and informative videos.
That would work for the outer electrode beautifully. Not sure how to create a satellite dish on the inner electrode, though.
