Old 10-04-2009, 06:40 AM   #21 (permalink)
Originally Posted by Mesuge View Post
You might be interested in connecting those three buttons wirelessly via basic strap on style steering wheel remote kit, in that fashion you can easily cycle through the different PIDs on the LCD and still be safely focused with both hands on driving.
That's an interesting idea. Elsewhere in the book there's brief mention of how to interface with the existing steering wheel buttons that are connected via floating contacts or clockspring electrodes, so I suppose one option would be to take over existing buttons rather than add new ones. The problem with a radio link is that most simple RF remotes won't handle multiple simultaneous presses, while the OBDuino relies on pressing multiple buttons to perform some actions.
By the way, I've now moved the OBDuinoMega branch to a repo on GitHub so that it's in a similar location to the other projects featured in the book:
github.com/practicalarduino/obduinomega
Cheers :-)
Jonathan Oxer
Geek My Ride: www.geekmyride.org
Practical Arduino: www.practicalarduino.com
The Following User Says Thank You to jonoxer For This Useful Post:
dewasha (07-16-2013)
Old 10-04-2009, 08:06 AM   #22 (permalink)
Do you think that your kit could evolve in the future in something like single pcb board solution as this "basic" CAN OBDuino. Obviously with that added functionality it doesn't have to be 1 DIN frame size oriented as Frederic
is planing for his boards:
http://ecomodder.com/forum/showthrea...ress-9643.html
OBDuino Hardware
OBDuino
According to this french written blog,
OBDuino pcb kits should be available Q4/2009 at pricetag < $75
http://www.hyperkilometreur.com/blog/?cat=6
And with such complex project why don't you just migrate up to ARM9 level,
you then can run it on WinCE5/6, Android, Linux/Angstrom, .. , including 3,5" touchscreen or bigger
http://www.watterott.com/ARM9
http://www.friendlyarm.net/home
http://www.andahammer.com/
http://ecomodder.com/forum/showthrea...uino-8778.html
and/or alternatively there is this PAL/NTSC TV shield called TellyMate
for Arduino, which could run small LCD panel, many code samples here:
http://www.batsocks.co.uk/products/S...e%20Shield.htm
http://www.batsocks.co.uk/products/S...d_Examples.htm
now incl. new firmware for larger/custom fonts&graphics:
http://www.batsocks.co.uk/#nogo
hooked to 3,5" 4:3 TFT (.5W) 640(H) x 480(V) RGB car display
(sold as for CCTV camera):
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=310100862640
OBD-II project for RAV4-EV:
http://www.idleloop.com/robotics/RAV4-EView/
The Following User Says Thank You to Mesuge For This Useful Post:
Old 07-16-2013, 07:37 PM   #23 (permalink)
this version of obduino show me this errors:
obduino32KMega.ino: In function 'void __vector_5()':
obduino32KMega:882: error: 'PINK' was not declared in this scope
obduino32KMega.ino: In function 'void serial_rx_on()':
obduino32KMega:1026: error: 'Serial1' was not declared in this scope
obduino32KMega.ino: In function 'boolean iso_read_byte(byte*)':
obduino32KMega:1062: error: 'Serial1' was not declared in this scope
obduino32KMega.ino: In function 'void iso_write_byte(byte)':
obduino32KMega:1083: error: 'Serial1' was not declared in this scope
obduino32KMega.ino: In function 'void iso_init()':
obduino32KMega:1265: error: 'Serial1' was not declared in this scope
obduino32KMega.ino: In function 'void setup()':
obduino32KMega:3106: error: 'hostPrintLn' was not declared in this scope
obduino32KMega:3120: error: 'hostPrint' was not declared in this scope
obduino32KMega.ino: In function 'void loop()':
obduino32KMega:3262: error: 'processHostCommands' was not declared in this scope
obduino32KMega.ino: In function 'void params_load()':
obduino32KMega:3637: error: 'hostPrint' was not declared in this scope
obduino32KMega:3657: error: 'hostPrintLn' was not declared in this scope
please help me to solution the error in the code, thanks
Old 03-22-2015, 11:55 PM   #24 (permalink)
Did anything more ever come from this project?
Pete
arduino, mega, obd, obduino
OBDuino working with ELM327 Magister OpenGauge / MPGuino FE computer 50 02-08-2025 10:46 PM
OBDuino CAN version only, progress! Magister OpenGauge / MPGuino FE computer 26 01-19-2011 09:03 AM
OBDuino Feature Request... electromike OpenGauge / MPGuino FE computer 13 07-23-2009 02:46 PM
OBDuino mod - no need of 'uino' Dominik OpenGauge / MPGuino FE computer 4 06-19-2009 10:41 AM
OBDuino and the 328p? gone22 OpenGauge / MPGuino FE computer 0 04-12-2009 09:56 PM
