Old 10-10-2009, 04:19 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 31.38 mpg (US)
Old Air dam= New Grill Block? What you think?
Hey my sister drives a jetta and her air dam was falling off multiple times (mostly because she cant drive and runs on curbs all the time) and She asked me to fix it again (it was hanging off one side) I told her I could fix it or just take the whole thing off and she told me to just take it off...
So then I got a air dam and I didn't really think about it until today but I could use it as a good grill block eh? light weight, durable, and big enough to cut to the size I need for my upper grill.
You opinions... I still have some foam core board, enough to re-make the grill block like 2 more times once mine goes bad from rain and stuff, should I just keep using that?
Also, the grill block is pretty scratched up, will that make the aero gain go bad?
Here are some pictures, the red squares are to show the random flat spots I could used to fit in my grill, the blue squares are ones that MIGHT fit...
ID:	4414   Click image for larger version
Old 10-10-2009, 04:25 PM   #2 (permalink)
90 day: 34 mpg (US)
You could probably notice a lot of things about myself from these two pictures, haha, maybe I should clean my room a little B4 I take pictures to put online
Old 10-10-2009, 04:26 PM   #3 (permalink)
No, don't go there, the molecular alignments in the structure are all wrong and will lead to heartache and dismay. and worse fe.
Old 10-10-2009, 04:28 PM   #4 (permalink)
I don't see any underwear or porn so you're OK.
Old 10-10-2009, 04:32 PM   #5 (permalink)
90 day: 34 mpg (US)
3 pairs of boxers in the first picture but not very noticable so I'm still in the green
Old 10-10-2009, 04:34 PM   #6 (permalink)
90 day: 34 mpg (US)
I figured once I cut out the square I would try to fatten it out as much as possible with heat and some flat pressure still bad idea ya think?
Old 10-10-2009, 04:35 PM   #7 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
I spy sketchers, which are a nono.
Old 10-10-2009, 04:37 PM   #8 (permalink)
90 day: 34 mpg (US)
I wear Vans, the sketchers were shoes I wore 1 time for graduation, I have tons of old papers in that box.
Old 10-10-2009, 09:41 PM   #9 (permalink)
90 day: 34 mpg (US)
So does no one have a thumbs up or thumbs down for this idea? Just one person?
Old 10-10-2009, 10:17 PM   #10 (permalink)
Aren't my answers all anyone could ever want?
Christ (10-11-2009)
air dam, air dams, foam core, grill block, grille block
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
grill "shield" rather than block? lunarhighway Aerodynamics 70 12-17-2010 03:50 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
