Old 12-09-2015, 10:15 AM   #2461 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by postmann2002 View Post
I wrote to less posts here, so I can't attach pictures.
Please contact me if you are interested.
You can sort of do links ... you just have to substitute ...
youtube dot com\rest-of-the-link
As for the parts - I am interested but the shipping is far more than the parts cost.
Old 12-09-2015, 11:34 AM   #2462 (permalink)
PaulH
MPaulHolmes's Avatar
If you spin an AC motor beyond its rated RPM, does it automatically start making a voltage on the 3 phases? I don't really get that if it does.
kits and boards
Old 12-09-2015, 11:50 AM   #2463 (permalink)
Here is a try to attach a link to my advertisement:
www(dot)ebay-kleinanzeigen(dot)de/s-anzeige/siemens-hochleistungs-komponenten-fuer-elektroauto-motor,-inverter/397342132-223-4863
Old 12-09-2015, 02:30 PM   #2464 (permalink)
yes, you are right.
I think, it's more interesting for the european ev-community.
here is the link to my advertisement:
ebay-kleinanzeigen dot de/s-anzeige/siemens-hochleistungs-komponenten-fuer-elektroauto-motor,-inverter/397342132-223-4863
ID:	19251   Click image for larger version
ID:	19252   Click image for larger version
ID:	19253   Click image for larger version
ID:	19254   Click image for larger version
ID:	19256   Click image for larger version
ID:	19257   Click image for larger version
ID:	19258   Click image for larger version
ID:	19259   Click image for larger version
Old 12-09-2015, 02:53 PM   #2465 (permalink)
Perhaps I mis-understood?
If you spin an AC induction motor and there is some small bit of magnetism left in the rotor, it MAY generate some voltage at almost no current. Nothing to do with over rated RPM.
Over rated RPM you wear the bearings faster, the rotor may not be balanced for the speed and may wobble ... and if the laminations in the rotor come loose there is a catastrophic failure as the rotor 'runs into' the stator.
Old 12-09-2015, 03:49 PM   #2466 (permalink)
PaulH
I was just trying to understand when a 3 phase induction motor acts like a generator. My thinking was, if it somehow acted like a generator while hooked up to the AC controller, it would be a good opportunity to test the simulated grid tie feature.
kits and boards
Old 12-09-2015, 06:10 PM   #2467 (permalink)
What I understand: if you overspin an excited 3 phase motor you generate a voltage that exceeds the volts applied to the field windings. Hence regen.
However what constitutes overspin and at what excitation levels I dunno. Huebner on Diyelectric or Major will have better answers.
Old 12-09-2015, 06:12 PM   #2468 (permalink)
The controller needs to supply the excitation for the field ... as well as the initial 'kick' for real power to get current flow through the rotor.
Back to basic principles - As you know, current cutting through the magnetic flux causes torque in motoring mode. The controller or the grid supplies the rotating magnetic flux .. so the rotor is still 'rotating' through the flux even when it is standing still.
... so pushing or turning (torque) the rotor through the magnetic flux causes current flow in generating mode. That works in a Permanent magnet generator without any power required for a start. For the electromagnets in the stator, you need electricity to 'start off' the generator. The self-exciting home generators have small permanent magnets in the stator somewhere ... or use a capacitor/battery combination ...
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (12-09-2015)
Old 12-13-2015, 05:40 PM   #2469 (permalink)
Update #1 for Dec 6
https://youtu.be/PQypjId5Bmk
MPaulHolmes (12-13-2015)
Old 12-13-2015, 06:14 PM   #2470 (permalink)
PaulH
Also, if you type "save" it will save the settings I hope. I haven't checked that it properly saves and loads everything with all the new settings available. So, hopefully you only have to set up the throttle once and then never again. Just remember:
Code:
0 < fault-throttle-position < max-regen-position < min-regen-position < min-throttle-position < max-throttle-position < 1024
If you type:
stream-raw-throttle 1
data-stream-period 1000
Then, you can do all the adjusting and it will show you on the fly what the raw throttle is. Then, you can choose what positions you want for fault, max regen, min regen, min throttle, and max throttle.
To stop the data stream, just hit enter.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
thingstodo (12-13-2015)
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
