Old 04-25-2010, 05:07 PM   #3361 (permalink)
Custom EV Builder...
Originally Posted by MPaulHolmes View Post
hahahaha yes! I believe! I also believe that little boy would have sunk in his little raft if he got much older! hahahaha
I'm almost ready to test the bms and charger! super super super close!
Hi Paul,
What's the chances of getting one of the atmega chips programmed by itself?
I looked over at your site but didn't see anything.
Thanks
Old 04-25-2010, 07:46 PM   #3362 (permalink)
PaulH
MPaulHolmes's Avatar
hello! the chance is 100%. I just ordered a few. I'll ask sabrina to post it again.
-Paul
kits and boards
Old 04-25-2010, 08:32 PM   #3363 (permalink)
-Paul
NICE
I have an idea for a style of controller of my own flavor.
How many gate drivers can it support?
Old 04-26-2010, 02:23 AM   #3364 (permalink)
PaulH
The control board right now just has a single spot for a driver, but the microcontroller can drive several mosfet drivers.
kits and boards
Old 04-26-2010, 09:16 AM   #3365 (permalink)
Excellent, just what I wanted to hear.
Old 04-27-2010, 04:53 AM   #3366 (permalink)
Eeeeeps... multiple user errors ... after my first successful testdrive
I was re-wiring and cleaning up the cables. Stupid me messed up there and now I am in recovery mode having a VREF out of range indication in the rtd explorer ...
If I measure +5V between SGND and +5V on the LEM but nothing between SGND and CURRENT does that mean my LEM is broken ?? Or could anybody suggest more measuring points that could indicate other defects ?
Old 04-27-2010, 11:26 AM   #3367 (permalink)
PaulH
Do you have one of the LEM HAS 300-S instead of LEM HASS 300-S? You can check by looking at the back of the sensor:
Does the back look like that?
kits and boards
Old 04-27-2010, 11:40 AM   #3368 (permalink)
PaulH
Could you remove the LEM from the circuit, and apply 5v power to the LEM, and then check Vref on the LEM? It should be approximately 2.5v. Also, Vout should read 2.5v too in that situation, because the current would be 0 amps. I know the cable is probably soldered to the control board, so it might mean making a new cable. If you are seeing 0v on Vout, then:
1. There's a short on the control board, so Vout is connected to system ground
2. LEM is broken.
3. Wrong LEM. (I don't think it's the wrong LEM if you were driving around with it)
kits and boards
Old 04-27-2010, 11:57 AM   #3369 (permalink)
very nice
Old 04-28-2010, 12:28 PM   #3370 (permalink)
ReVolt Enthusiast
Australian - Open Revolt (COUGAR) kits
I found the link below for Rev.D Controller kits.
Not much said in this fourm about this kit
Electric Vehicle Parts
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
