Old 07-01-2011, 03:17 PM   #4901 (permalink)
jackbauer's Avatar
thanks Paul!. I got the 1ka control board running today. Had to fool the traction voltage sensing and hardware undervoltage circuits as i'm just bench testing. I mounted the melexis current sensor on a piece of 20mm x 10mm copper bar as per the photo and shorted out a fully charged 7ah gel battery. It managed an impressive 162amps according to rtd.
I'm tentatively looking at 4 of these for the power stage:
IGBT Modul FUJI 1MBI800U4B-120 | eBay UK
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
MPaulHolmes (07-01-2011)
Old 07-01-2011, 03:34 PM   #4902 (permalink)
PaulH
MPaulHolmes's Avatar
Hi jack! That's awesome! Just so you know, the hcpl-4506 optocoupler is basically worthless for your application. Make sure you go straight from before the opto to the igbt driver board. There's a big hole for that.
kits and boards
Old 07-01-2011, 04:05 PM   #4903 (permalink)
jackbauer's Avatar
Yeh i saw that , thanks. What's the story with the traction voltage sensing? I saw a max_voltage parameter on rtd. Can i set the point at which the contactor closes etc? Will it shutdown on low voltage?
www.evbmw.com
Old 07-01-2011, 11:29 PM   #4904 (permalink)
PaulH
The max_voltage parameter was some half baked idea about not closing the main contactor if the precharge voltage got too high. But it could be used for all sorts of things. The precharge circuit doesn't need to know the max voltage to work though. It's based on change in voltage over time. What it does is, if there has been ZERO change in voltage in the last second, and the voltage is sufficiently greater than zero, then the caps are full, so close main contactor.
kits and boards
Old 07-04-2011, 02:44 PM   #4905 (permalink)
jackbauer's Avatar
Hello everyone. My name is Damien and i'm a controlerholic
ID:	8890   Click image for larger version
ID:	8891   Click image for larger version
www.evbmw.com
The Following 5 Users Say Thank You to jackbauer For This Useful Post:
deodeo (04-20-2012), KUSAW (07-14-2011), LouMan (07-04-2011), MPaulHolmes (07-04-2011), thingstodo (07-24-2011)
Old 07-04-2011, 03:47 PM   #4906 (permalink)
PaulH
haha. I'm on step 1 of the 12 step program.
kits and boards
Old 07-04-2011, 04:51 PM   #4907 (permalink)
Hi Damien!
Old 07-04-2011, 05:04 PM   #4908 (permalink)
PaulH
hahahaha
kits and boards
Old 07-05-2011, 04:08 AM   #4909 (permalink)
Tazzy - '02 Toyota Tazz Sport
90 day: 43 mpg (US)
Beautiful!
Old 07-06-2011, 04:20 PM   #4910 (permalink)
jackbauer's Avatar
Looks like the VLA is driving my gate off too fast. Common problem at my age i'm told
www.evbmw.com
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
