Old 08-15-2017, 09:46 AM   #7201 (permalink)
tnx
will those work with your logic ?
FUJI 1MBI600U4B-120
Old 09-10-2017, 02:48 PM   #7202 (permalink)
Hello.
I'm trying to write soft for Field Oriented Control of induction motor. I have finished 3ph 3kW inverter, controled by STM32F4, and V/F open loop algorithm to control ACIM - it works. Now I'm trying to implement FOC algorithm rewriting code from this project using float variables.
CortexM4 have FPU so operations on floating points numbers take same time (cycles) as operating on integers.
Here is part of code:
Code:
void ClarkPark(float L1_curr, float L2_curr)
    vector.Ialpha = L1_curr;
    vector.Ibeta = (L1_curr + 2.0*L2_curr) / 1.732;
    //Id =  Ialpha*cos(Angle) + Ibeta*sin(Angle)
    vector.Id = vector.Ialpha*cos(vector.AngleFluxDeg) + vector.Ibeta*sin(vector.AngleFluxDeg);
    // Iq = -Ialpha*sin(Angle) + Ibeta*cos(Angle)
    vector.Iq = (-1.0)*vector.Ialpha*sin(vector.AngleFluxDeg) + vector.Ibeta*cos(vector.AngleFluxDeg);
//qdImag = qdImag + qKcur * (qId - qdImag)      ;; magnetizing current
void curModel(void)
    vector.Imag = vector.Imag + (LOOP_PERIOD / ROTOR_TIME_CONST) * (vector.Id - vector.Imag);
    if(vector.Imag == 0) {
        return;
    // VelSlipRPS = (1/fRotorTmConst) * Iq/Imag / (2.0*pi)
    vector.VelSlipsRPS  = (1 / ROTOR_TIME_CONST ) * (vector.Iq / vector.Imag) / (2.0*PI);
    //VelFluxRPS = iPoles * VelMechRPS + VelSlipRPS
    vector.VelFluxRPS = 2.0 * speed.perSec + vector.VelSlipsRPS;
    //AngFlux = AngFlux + fLoopPeriod * 2.0 * pi * VelFluxRPS
    vector.AngleFluxRad = vector.AngleFluxRad + LOOP_PERIOD * 2.0 * PI * vector.VelFluxRPS;
    vector.AngleFluxDeg = vector.AngleFluxRad * (180.0 / PI);
Please tell me If I'm wrong:
I have to keep an eye on vector.AngleFluxDeg variable to be value between 0 - 360 degree? (back to 0 if 360 overflowed).
It will be correct?
Thanks for any reply.
Old 09-13-2017, 07:08 PM   #7203 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I think that maybe this should be moved to the AC controller thread? Do you need to be a moderator to do that?
As for the translation of the code, you should be able to run the code as Paul wrote it. The floating point variables should work as written. It appears to be ansi standard C with no goofy library calls.
If you want to optimize the math to make better use of your floating point math library, I'd suggest doing that after you have Paul's math running. Just my opinion. That way you can run through a test set for your math before your changes and after your changes to make sure it still works!
As for the range on degrees, you should be able to use the modulo or mod() function on your angle to bring it back to the range 0 - 360. It won't matter for the intermediate calculations. Sin(0) = sin(360) = sin(720). It is only convention that shows the angle between 0 and 360 degrees.
Hope this helps
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (11-21-2017)
Old 11-21-2017, 02:00 PM   #7204 (permalink)
PaulH
MPaulHolmes's Avatar
Yes, thingstodo, and I actually use 0-65535 for the "degrees" so that when it rolls over, it automatically goes back to zero, so you don't have to worry about it.
mfox: I would use either a high side IGBT with a diode on the low side (I think they call those choppers), or an IGBT half bridge, since you need a freewheel diode too, and just just the IGBT. So, the part you listed wouldn't work for that.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
mpgmike (01-25-2022)
Old 02-07-2018, 07:30 PM   #7205 (permalink)
Hey, folks - Paul supplied me with a DC board for IGBTs and has been helping me with my controller. Seeing as he's pretty busy right now, does anyone have a current copy of the DC control software? I've read through a ton of posts, and I keep seeing messages about the software being sent back and forth, so hopefully someone can lend a hand Thanks!
Old 02-07-2018, 10:52 PM   #7206 (permalink)
EVVette - '71 Chevy Corvette Coupe
Index of /firmware
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 02-09-2018, 09:05 PM   #7207 (permalink)
The code I have for the IGBT DC version (Paul doesn't call it the cougar) does not compile for me on MPLAB X. This zip file does include the .hex file for .. I think it's version 7 that Paul uses?
Dated April 4, 2017 ... even though the zip file shows it is today's date.
This is the version I was running when I posted the test videos
Old 02-09-2018, 09:06 PM   #7208 (permalink)
Hmmm .. if Paul sent you the board, it should already have the latest firmware loaded ... but it never hurts to have the source files!
Old 02-10-2018, 02:47 AM   #7209 (permalink)
You are correct, I believe that it was loaded already. I was having a lot of trouble getting it to respond, however, so I made a mess of it XD I figured it would be easier to find a current copy of the software, but I was mistaken.
I am having a ton of trouble connecting to the controller via realterm.
I appreciate everyone's help!
Old 02-11-2018, 10:05 AM   #7210 (permalink)
Well, I'm getting no response over serial no matter what software I load on the chip, what terminal application I use, what cable I use, or what computer I use. It doesn't respond to throttle and never switches the IGBTs. The board is very different from the rest of these - I've attached some pictures. I think I'm stuck waiting for Paul to send the software.
Name:	Control Board.jpg
ID:	23480   Click image for larger version
Name:	Control Board 2.jpg
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
