Old 04-14-2009, 12:14 PM   #921 (permalink)
I like the idea of multiple beta testers to get a broad range of information. I'd be willing to test if there is a need on my 96 volt Civic once I get my FB1-4001 installed. I know have a Kelly and I could do a straight comparison at 96 volts between the two.
Anyways, I'm itching to see version 2 and find out what the real cause of the bust was.
Old 04-14-2009, 04:41 PM   #922 (permalink)
Originally Posted by MPaulHolmes View Post
I also am adding a zener diode (I never knew what those really were until today. Don't tell anyone! It's a secret. I'm the "expert" hahahaha!) to not allow voltage spikes from gate to source. It will clamp the voltage from gate to source to no more than 20v. The voltage from gate to source can now freely rise to 20v, and then all of a sudden, BAM! NO MORE! HAHA! If even a small voltage spike of 30v hits the gate, it can destroy the mosfet. That could have been what happened last time. Now, that potential problem is eliminated!
Two quick notes on the zeners:
1) Make sure that the zener is tied after the gate resistor. Zeners need to be current limited, or they release their magic smoke.
2) Do a quick power rating check to make sure that the zener is beefy enough, If you have a 20 ohm gate resistor and are clipping the voltage to 20V, then a 30V spike will draw a half amp's worth of current (30V-20V)/20 ohms and would need 5W to dissipate.
ga2500ev
Old 04-14-2009, 05:27 PM   #923 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
Roger, thank you for your explaination of the pack voltage details... you filled it in a little better than me
SGC, it would be great if we could do some multiple voltage level beta testing
ga, I don't think you need to worry about that. We are not trying to protect from someone hooking up a 30-volt power supply. We are just trying to protect from spikes. A 1us spike may generate 5W for 1us, but that won't generate any heat. As long as it can handle the peak current and voltage that we need to clamp, it is no issue.
As for prototype PCB professionally made... Did I ever mention that is exactly what the company that I work for does? I had a word with someone here. THIS IS NOT OFFICIAL INFORMATION. If Paul were to source the parts from Digikey and source the boards from PCBCart.com or one of the other el-cheapo custom board houses and put all that in a box and send it to us... we could ship him 10 control boards, wave soldered for under 500 bucks. This would be visually inspected, no special certifications, etc. The more we make, the better the "per board" price. The more we do (sourcing parts, surface mounting, post-testing) the more cost.
So Paul... PM me if you are interested. I would not bother with less than 10 as the fixed costs would make the board price a little silly.
On the other hand... I'd seriously find the time to solder everything by hand myself for Beta testers...
Old 04-14-2009, 06:13 PM   #924 (permalink)
Location: 15 miles away from Robbinsville, NC on a mountain
Ivan - '89 Chevy 1500
Dude. One word: WOW I spent 7hours reading this today and all i have to say is wow. You did it. WHOOT WHOOT!!! Cheering you on!
Old 04-14-2009, 06:17 PM   #925 (permalink)
PaulH
MPaulHolmes's Avatar
I talked to Fran, and I have a few things to change now. Really sneaky subtle things! It's all pretty easy to change though. Nothing too hard. After a few more iterations to make sure everything is good, I'd like to breadboard it to try it out before getting PCBs made.
Thank you Kijana! This thing is getting really long, huh! 7 hours! geeze!
kits and boards
Old 04-14-2009, 06:21 PM   #926 (permalink)
yeah. im on spring break so i was bored. read all of ben's electric metro coversion. then found the link for this and read it all. yikes huh? its pretty darn sweet.
Old 04-15-2009, 01:44 AM   #927 (permalink)
Wherewolf's Avatar
What I personally think would be really cool: Make up some basic instructions (maybe videos?) that would show techniques for hand soldering different types of components - when to use more heat, when to use less, the use of flux , desoldering, etc....I know there are clamps to dissipate heat to protect components, what to buy, additional tips, resources, etc... to help the others involved in this.....just a thought....
Shared Knowledge is Best...Put the forums to the Test.
Wherewolf
Old 04-15-2009, 02:03 AM   #928 (permalink)
EcoModder Student
esoneson's Avatar
Soldering instructions
Wherewolf,
I found several soldering instructions on YouTube and I think there are some at the instructables web site too. Google is my friend.
Eric
1995 BMW 318i EV in the making
Old 04-15-2009, 09:03 AM   #929 (permalink)
I have no problem soldering components together, but I do have a problem with the milling of the PCB. I don't have the tools to do it, but this summer I might play with PCB liquid etching.
Maybe if "Beta Kits" were made, like all the Buss Bars and PCB was already cut to spec, then the the "Beta Kit" tester just soldered everything up. It would make an excellent test of the kit from start to finish.
Old 04-15-2009, 10:13 AM   #930 (permalink)
Wherewolf's Avatar
Originally Posted by esoneson View Post
Wherewolf,
Eric
I understand that there are instructions out there, I was thinking more of specifics related to this project - any tricky issues with soldering the components particular to this controller - caps, mosfets, diodes etc....
Wherewolf
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
