Old 02-18-2023, 09:10 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Photochop butchery ( aeromodding cars using Photoshop )
I've done some image editing on cars that I can't modify in real life. ( No garage ...and no money ! )
These are just doodles I have done on my phone ( So not actual Photoshop, of coarse )
The one I did today, was a 1st gen. Nissan Leaf.
What if you took a SawZall to the A pillar and leaned the roof back ?
I'd make it a 2 door, with enough room in the back for my dog. I have never had a need for back seat passengers anyway.
Side window glass would have to be reworked. The back doors could have plexi as a window material.
The doors would still open from the inside, but not with the intention of having passengers back there other than my dog.
The roof would have a section cut out for a plexiglass window - or maybe an actual rear window fused in from a junkyard car ( whatever fits )
It would be hinged and be a hatchback.
The headlights and grlle would be reworked to be flush and maybe have some scoops for some air curtains.
The boattail would collapse into itself for city driving.
Here is my inspiration :
ID:	33447   Click image for larger version
ID:	33449   Click image for larger version
ID:	33451   Click image for larger version
ID:	33452   Click image for larger version
ID:	33460   Click image for larger version
The Following 3 Users Say Thank You to Cd For This Useful Post:
aerohead (02-20-2023), Gasoline Fumes (02-19-2023), ME_Andy (02-18-2023)
Old 02-18-2023, 10:49 PM   #2 (permalink)
Growin a stash
Amazing that you could do that on a phone.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following User Says Thank You to ME_Andy For This Useful Post:
Old 02-19-2023, 12:08 AM   #3 (permalink)
I was thinking of your inspiration before I got to the bottom of the post.
I've thought of a slant chop on another car. I'd cut across the cowl, right back to the back of the A-pillar. Then add metal into thte gap that opens up
It's good to see you're still including the boat tail. You like blue?
Old 02-19-2023, 10:09 AM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
ME Andy - yes it's a bit nuts to do this on a phone. Even worse is trying to upload it to Ecomodder. My phone jumbles all the images and i dont get a full preview ( the view is cropped ) and i have to guess which pne Im uploading.
What is crazier still, is that I tried doing a 3d model hack on my tablet, but it is so old that I can't zoom in without it falling apart .
So I am going to attempt to edit the model on this phone too : )
Freebeard : That's pretty much what I'd do too. The entire wiper assembly would fall back to the angle of the windshield.
As far as blue, no I don't care for that color. I just included that image because it is such a common color for Leaves.
I would take mine down to bare metal and give it a cyberpunk look.
Plastic bumpers could have sheet steel riveted to them.
The Following User Says Thank You to Cd For This Useful Post:
freebeard (02-19-2023)
Old 02-19-2023, 02:14 PM   #5 (permalink)
Passat TDI Wagon - '97 VW Passat Wagon TDI
90 day: 49.82 mpg (US)
Blue - '21 Hyundai Sonata Blue
90 day: 47.54 mpg (US)
that is tempered curved glass on the side windows, so it can't be cut after the top is chopped.
What you could do is play with the regulator and window and not roll up the window all the way to simulate the chop, then tilt the side window glass back in the regulator to match the new roof taper. if you find something that works with the side windows and still rolls up and down, then chop the door frame to match the window rolled up. Then chop the roof to match the chopped doors.
If you chop the roof per your mockup first, you would be stuck using lexan side windows and would be lucky to get one to roll up and down.
You can lay the windshield posts and windshield back but would only be worth a few tenths of sq. foot of frontal area reduction, but would be a ton of work. In a typical roof chop, the roof needs to get wider at the top or the side window slope has to change. They usually put in a filler piece strip in the center of the roof to make it wider.
97 Passat TDI Wagon
Bosio 520 DLC nozzles, chip tune
Mufflerectomy, ALH Injection Pump
317k miles
Scan Gauge II
full belly pan
26 gallon tank
The Following User Says Thank You to Caddylackn For This Useful Post:
Cd (02-21-2023)
Old 02-19-2023, 03:18 PM   #6 (permalink)
https://www.onedayglass.com › can-you-cut-tempered-glass
How To Cut Tempered Glass Into Your Desired Size Or Shape - One Day Glass
Tempered glass is a kind of safety glass that is manufactured to ensure that if it breaks, ... Typically, only professionals with special laser cutters can cut tempered glass. Various how-to guides will tell you that you can cut tempered glass by first annealing the piece. It involves placing the tempered glass panel into a craft oven or a kiln ...
Else pop-outs.
Cd (02-21-2023)
Old 02-20-2023, 10:11 AM   #7 (permalink)
'Prius'
*I'd want to analyze the roofline for deceleration overshoot. NISSAN has used a CALTY roof like that on their Z-Cars for decades, but they never demonstrated any remarkable low drag attributes. It might be okay, but it would be prudent to validate.
* On the rear diffuser, I'd take the SAE 10-degree 'departure' angle, projected up from the back of the rear tire/ground interface, and lower the rear transom lower trailing edge to that imaginary line. It's my opinion that, the up-slope as presented, would never support low drag.
Old 02-20-2023, 12:28 PM   #8 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
What app are you using? I’ve been wanting to doodle some Ioniq boat tails before fabricating a real one with dibond and a detachable hitch mount
Old 02-20-2023, 12:50 PM   #9 (permalink)
What tablet? What phone?
I've been painting everything (stool tops, shelves) Slate Blue. Me like. Instead of riveted sheet steel, maybe a metallic Plastidip?
Old 02-21-2023, 05:23 PM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Aerohead, I know what you mean about the sudden roof slope.
I was surprised at the detached flow on the roofline of the 240-Z - especially when I have seen airflow remain attached on sharp corners that I never would have thought would work.
The slope on the 350 - 370Z seems to work though. The cD is .29, despite the massive wheel openings and flares.
Agreed about the floor slope angle. I got sloppy with that.
aerohead (02-23-2023)
