Old 01-16-2016, 08:10 AM   #71 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Originally Posted by Joggernot View Post
For some reason I can't see the photos.
I can't either.
The Following User Says Thank You to iveyjh For This Useful Post:
planejob (01-16-2016)
Old 01-16-2016, 10:48 AM   #72 (permalink)
BeginnerModder
I think I fixed the pictures. let me know. I had to switch from photobucket to google photos - Google normally rocks, but their photo album is convoluted.
So, you may have noticed that the engine has to be rotated a few degrees in relation to the transmission/gas engine position in order to expose 1 of the 2 bolts at the top of the tranny. Tip o' the hat to Kimer for the heads-up on this - I went into it expecting to have to make the rotation and it worked fine. I was careful to rotate it in such a manner that the starter hole did not interfere with the engine block. Oh yeah, it would have been all too easy to Leeroy Jenkins this thing and end up with an adapter plate that had all sorts of interference.
I've been talking about the factory dipstick for several posts now (that means...... ahhhh... more than a month. sorry about this.) I used an expanding plug from the Home Depot to push into the dipstick hole and the <gasp> I put a 1/4-20 bolt into the plug and snugged it up, causing the rubber to expand and lock, as designed. I can't believe I mixed in SAE bolts
Stream of consciousness recap: I still need to drill the new dipstick hole. Perhaps today? who knows. Anyway... here's a few pictures of the mated assembly. Notice the starter and injection pump and on the same side of the block - they will be to the rear when mounted in the car. The transmission case supplies 2 of the three needed mounting points, so I will only have to fab up 1 motor mount for the right/passenger side. Half good news half bad news: I'm switching from an auto to a manual tranny so my axles are not compatible, the CV axle ends vary between auto and manual and the length of the axle varies between the 3 cylinder and 4 cylinder mounting points. I'm changing from 4 cylinder mounting point to 3cyl mounting (maybe, hopefully, my measurements are right and there will be enough room.) and changing from auto to manual. So I had to order new CV axles. That's bad news. RockAuto had the axles for 23 bucks a side. SOLD, SHIP THEM. That's good news. This means I have the current axles and nothing to do with them... wait, I need to be able to roll the car out of the garage to install the engine. So I'll deconstruct the automatic CV axles and use the stubs in the wheel-end to hold the bearings together while rolling. That's some good news.
Enough rambling, Here are the pics I promised:
The Following 3 Users Say Thank You to planejob For This Useful Post:
bikeprof (03-14-2016), Daox (01-16-2016), iveyjh (01-16-2016)
Old 01-16-2016, 01:02 PM   #73 (permalink)
I don't see them here either, now. As far as my garage...some kid down the street told me that I had the junkiest garage on the whole street....but that was OK because it was all ''good junk''. Yup, somewhere in there is a 4 wheel drive Triumph Spitfire powered by an injected Chevy V-6. Pretty good junk! My comment stems from snickering at my neighbors garage.... the total contents...a BMW and a set of golf clubs. Nothing else.
The Following User Says Thank You to kimer6 For This Useful Post:
Xist (01-16-2016)
Old 01-16-2016, 02:42 PM   #74 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
Good news here. I can see all the pics
Nice work so far!
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 01-16-2016, 04:26 PM   #75 (permalink)
Diesel Geo
Great job!
Yes, it can put a smile on your face.
Note how small this 3 cylinder diesel is.
A turbo is optional!
ID:	19466   Click image for larger version
Name:	shoe diesel.JPG
ID:	19467   Click image for larger version
Name:	sidewinder diesel.JPG
Old 01-16-2016, 05:18 PM   #76 (permalink)
BeginnerModder
That picture with the shoe is awesome.
Old 01-16-2016, 08:57 PM   #77 (permalink)
I need to learn how to post photo albums. Well, maybe next week. Here's my steel adapter plate. The dowels are permanent fixtures. Any Geo transmission will bolt right up and be aligned like a factory engine. The starter even has dowels.
ID:	19472   Click image for larger version
Name:	g13 flywheel.JPG
Old 01-16-2016, 09:04 PM   #78 (permalink)
Originally Posted by kimer6 View Post
Great job!
A turbo is a good thing to consider, not just due to the performance improvement but also as it provides some mild degree of noise suppression. BTW one thing that would sound cool is a twincharger setup with the turbo and a blower, which would decrease the turbo-lag.
Old 01-16-2016, 09:17 PM   #79 (permalink)
Rooster, I like to diesel power everything. I have a 21 foot fishing boat that I turned from an inboard to a Mercruiser Bravo One stern drive with a Chevy 6.5 turbo diesel that I adapted. Here it is early on when it began running right, no more bugs... It would do 42mph, fast enough to hit a floating log and tear something up. 25 is nice and safe.
Old 01-16-2016, 09:18 PM   #80 (permalink)
90 day: 30.54 mpg (US)
What is this?! An engine for ants?! The engine has to be at least... three times bigger than this!
Awesome project and it is always great to see your progress!
Can you take a picture with a red hat and a pipe wrench?
deejaaa (02-09-2016)
