Old 10-20-2017, 06:19 PM   #1 (permalink)
D15r's Avatar
Civr - '95 Honda Civic Ri
tinkerbell - '90 Honda integra xsi
smokey - '00 honda civic gli
90 day: 43.36 mpg (US)
takaka - '00 toyota echo base with ac and ps
post your idling L/hr consumption and....
post your idling L/hr consumption and if you have it readily available no load per hour fuel consumption
@2000, 3000, 4000 rpm
Please post: engine type, idling rpm (state lowered or stock), and any mods that might effect consumption: eg, no ps no ac belts etc
Thanks
Old 10-20-2017, 06:25 PM   #2 (permalink)
D15r's Avatar
Ill start with mine:
civic ek1, d16y4, 1590cc, no ps, idle speed lowered to 720rpm.
.71 l/hr,
edit I re calibrated my mpguino and I believe it to be more accurate now. So new figure is .63l/hr at idle.
Also I tested at 2k rpm ...3...and 4k here are the results:
2k, 1.5l
3k, 2.6l
4k, 3.8l
I plotted this as a graph, please note my math skills are rusty very rusty but it appears it appears to be a linear graph or very close to it, at least up to 4k rpm I didn't test higher I should have but I didn't want to make anymore noise pollution.
I'd still like to get the idle speed down, I managed to get it to drop to very low rpm while I was water injecting, don't ask, the mpguino was reading .45l/hr! Although at that low rpm it wasn't smooth enough, but still I should be able to get close to that figure with a stable idle.
Old 10-20-2017, 09:34 PM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
0.0 because I don't idle.
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
D15r (11-06-2017), Fat Charlie (10-23-2017)
Old 10-20-2017, 11:50 PM   #4 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
I measured mine a while ago, before I removed the power steering.
2006 Accord V6, J30A5, 2997cc, stock(at the time), 700 rpm(stock, will have to verify actual rpm with scanguage)
1.32 l/hr
EDIT: Idle speed spec is actually 750 rpm, mine seems to hover right around 770 rpm. I have since brought out the the GPH gauge again after removing my power steering and have seen as low as .32 GPH(1.21 l/hr), but most of the time it sticks around .34 GPH(1.29 l/hr).
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
D15r (11-06-2017)
Old 10-21-2017, 05:13 AM   #5 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Suzuki (Geo/Firefly) G10, 1.0l, 0.45L/hr. Hot/warm air intake keeps idle speed and consumption down.
The Following User Says Thank You to Stubby79 For This Useful Post:
D15r (11-06-2017)
Old 10-21-2017, 05:33 AM   #6 (permalink)
D15r's Avatar
It's interesting to see others consumption at idle, I geussed my idle consumption initially and used it to roughly set my mpguino, ended up being very close.
Low Idle consumption is also good for key on coasting, I don't generally turn my motor off.
Old 10-23-2017, 01:01 AM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
3.5L V6, manual transmission, coolant-based warm air intake
warm idle is 1.1 L/hr at idle of 600 RPM.
The Following User Says Thank You to t vago For This Useful Post:
D15r (11-06-2017)
Old 10-23-2017, 07:01 PM   #8 (permalink)
2015 WRX - '15 Subaru WRX
90 day: 30.63 mpg (US)
2008 Suzuki SV650SA - '08 Suzuki SV650SA
90 day: 60.81 mpg (US)
1998 Acura Integra GS-R: 1.0L/hr
2015 Subaru WRX: 0.8L/hr
Both stock idle rpm with a warm engine.
Old 10-24-2017, 09:00 PM   #9 (permalink)
D15r's Avatar
I have to remember to test the no load consumption as rpm rises. I'll be going for a drive tonight so I'll remember to check and record data. I did my valve tappet clearances a few were on the tight side so hoping to see some improvement at idle if only a tiny one. I might have to block the tb by pass hole in order to further lower my idle speed. Potentially that could mean .2l per hour savings seems worth it, as I do a lot of engine on coasting.
Edit I checked and adjusted my valve clearances and advanced my timing unsure of exact degrees , this seemed to show no effect to my idling fe.
Old 10-25-2017, 02:22 AM   #10 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
1.2 litre Honda Jazz. 0.68 litres/hour at 700 rpm.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
