Old 10-03-2010, 09:49 AM   #51 (permalink)
Wiki Writer
bugler - '91 Mazda 626
90 day: 35.89 mpg (US)
4ringcircus, I did the same thing as yourself and thought no way people cant drive around like this its way to much effort to turn. When i looked more into it i found if you remove the power steering hydraulic lines the effort becomes significantly easier. I am not sure about a 4x4 but for my car it worked well and i dont even notice the effort in steering (until i get into another car and turn with much more effort than i should).
have a look at the wiki if your interested in trying it out as i have put in some pictures and a how too instruction for the mod.
Power steering delete - EcoModder
The Following User Says Thank You to saand For This Useful Post:
j12piprius (04-19-2014)
Old 10-03-2010, 08:24 PM   #52 (permalink)
On my '95 Saturn TDI project, I just cut the lines off the fittings and used a piece of 3/8" fuel hose to loop between the two. For awhile I thought about trying to refit the VW power steering pump in a different location, but I found that I really didn't miss the power steering. It does take some effort at very low speed, but it's not a Herculean effort, either.
Old 03-26-2012, 11:17 AM   #53 (permalink)
bheadrick's Avatar
Nissan Sentra - '01 Nissan Sentra GXE
90 day: 46.29 mpg (US)
if your water pump is on the same belt, how do you go about removing the belt from the power steering? Can you get a smaller belt that doesn't have to go around the power steering pulley?
Old 03-26-2012, 04:20 PM   #54 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
i would like to take out my p/s belt and bypass the lines but can someone give me clearly instruction on aow to do this please (my power steering have is own belt)
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 03-26-2012, 05:12 PM   #55 (permalink)
Now I've done power steering delete for fuel economy gains, but I don't drive enough anymore to post any reports quickly.
Old 03-26-2012, 08:19 PM   #56 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I did this last year on my car, which is similar to yours in that the power steering pump was run off its own belt. It's fairly simple (remove pump, belt, lines, and replace with a loop between the pressure and return lines at the rack, with an extra hose if you want a reservoir), and I followed this DIY: DIY: Removing Power Steering - Honda Civic Forum You'll need to figure out what size/thread the rack fittings are for your car before you can replace them, but the rest should be analogous.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
Old 03-26-2012, 08:32 PM   #57 (permalink)
40-60-40 MPH P&G
what did you do with the power steering liquid?
MPG=1 TIME=0
Old 03-26-2012, 09:29 PM   #58 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
use it for weed killer.... J/K
Old 03-26-2012, 11:47 PM   #59 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
pulled the belt on the side kick a year or more back.
its very light for a RWD suv, has narrow tires, with high pressers.
takes some force at a stop 60LB at the very very most, but really not that bad.
thus the mpg gane is in the less then 1 mpg range.
id gane more from a clutch fan swap out, than the P\S belt removal.
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
Old 03-27-2012, 11:06 AM   #60 (permalink)
Moderator
Vman455's Avatar
I drained it into an old milk jug and mixed it in with my old motor oil the next time I changed it and brought it in for recycling. I do the same with coolant and other fluids that I can't legally dispose of, too.
I live in an apartment, so I don't have to worry about weeds!
"underdrive" power steering pump? gascort EcoModding Central 11 03-04-2017 07:44 AM
Converting power steering to electric power steering Daox EcoModding Central 54 01-17-2017 06:16 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 01:23 PM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 12:42 AM
