Old 03-08-2013, 02:45 AM   #31 (permalink)
Originally Posted by Cobb View Post
Mr Plug in Hybrid suggesting a Diesel?!?!?!?!
Actually it seems like he was stating that a Diesel is a better option than using the Prius' internal-combustion engine alone.
Old 03-08-2013, 04:18 AM   #32 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
I don't know all the nitty gritty details of each engine (mounts/transmission bolt pattern, etc.), but if you yanked the 1NZ-FE engine out of an Echo, and installed the intake manifold, exhaust manifold, accessory brackets, etc. from it onto a 1NZ-FXE engine from a Prius and used the stock Echo harness and ECU, it will probably work. Probably. Maybe.
And if it does work, there will definitely be an efficiency advantage - 13.0:1 vs 10.5:1 to be exact. 25% less power, but who cares about that.
Old 03-08-2013, 05:19 AM   #33 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I just have another idea for Prius... To buy a Prius strip it off from any weight you can get rid off and put a small powerfull and very efficient diesel engine like 1.4 or 1.2 TDi
With Prius aero and lightened body that should give amazing FE numbers.
I have to think of that more Maybe a new project? (Wife will kill me )
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 03-08-2013, 08:14 AM   #34 (permalink)
Unless you swap in a tranny, the power splitter is going to require the die-sel egine to turn 5 grand to achieve highway speeds.
Old 03-08-2013, 08:19 AM   #35 (permalink)
AndrzejM's Avatar
I was thinking of swapping whole drivetrain with gearbox not just plug in diesel engine to Prius power splitter. So that wouldn't be a hybrid anymore. I'm thinking of Prius body with fuel efficient diesel drivetrain.
Old 03-08-2013, 08:59 AM   #36 (permalink)
Oh, well the hybrids are rather hogs with the battery pack and drivetrain removed. I think there is like a 20 lb difference between the weight of my insight and my sidekick. Not sure the dieselengine vs the synergy drive would produce the same mpg, aero is just one aspect of the prius or insight design to save fuel. You may be better for mpg to go with a geo or first gen insight.
Old 03-08-2013, 09:02 AM   #37 (permalink)
AndrzejM's Avatar
I like Insight but those are very rare here in Poland. TBH I haven't seen one on the street yet.
Old 03-08-2013, 12:37 PM   #38 (permalink)
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
OMG, go away with that stinky rattlebox! the poor prius didn´t deserve this torture. strip it and be happy or sell it and by a golf...
kurzer Gruß
Prius II
Hyundai Santamo
The Following User Says Thank You to kurzer For This Useful Post:
Cobb (03-08-2013)
Old 03-08-2013, 01:04 PM   #39 (permalink)
Its my assumption that the other countries have plenty of eco cars and other vehicles. Its the US who still drives around vehicles the size, shape and weight and mpg of the tanks our auto manufactures use to make for the world wars.
Old 03-09-2013, 05:43 AM   #40 (permalink)
I've already considered to do a similar project. Altough I'm often labeled as a "Prius-hater" I don't really hate it so much. BTW maybe the drivetrain out of some Peugeot or Citroën with an e-HDi engine would be perfect
