Old 04-14-2013, 04:36 PM   #1 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Project: The AeroMetro
I've been over on geometroforum.com for a few months now planning out the mechanical aspects of my project, but now that I've settled on a plan and put all my orders in online, I figured I would start a thread over here to document my work.
The goal of my project is to modify a 1993 Geo Metro XFi so that it capable of 100 MPG.
How am I going to do that you ask?
Well, here are the main contributors to my goal:
  • turning the Metro into a 3 wheeled reverse trike. This will drastically cut weight and allow the vehicle to be more aerodynamic.
  • Full streamlining. Shooting for a .16 Cd
  • Megasquirt ECU for full fuel control
  • Engine parasitic loss modifications
Those are the main points of my project.
Here are some pictures to help you visualize the plan:
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following 2 Users Say Thank You to HydroJim For This Useful Post:
aerohead (07-13-2013), HHOTDI (07-21-2013)
Old 04-14-2013, 04:39 PM   #2 (permalink)
HydroJim's Avatar
I received my first parts in the mail recently and I have a lot more on the way:
Lightweight flywheel from a Suzuki G13 engine. Along with the clutch disk and pressure plate, the whole rotating assembly is 1.4 lbs lighter than the assembly from a G10 and it gives more clutch area for slower wear and a stronger feel.
Stainless Steel Engine fastener kit. Everything is there except the manifold studs. This doesn't really help economy, but it's a nice thing to have for my engine rebuild.
The Following User Says Thank You to HydroJim For This Useful Post:
Old 04-14-2013, 06:38 PM   #3 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Interesting project. Is that photo of your car or an example from someone else?
Any reason you're going for four tail lights? Seems you could use two LED trailer lights and keep the wake smaller. The kit I used on the Probe was $40.
Old 04-14-2013, 09:45 PM   #4 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
With three wheels, it likely will legally be a motorcycle when you're done.
Coast long and prosper.
Old 04-14-2013, 10:58 PM   #5 (permalink)
HydroJim's Avatar
Sven7- the photo is of someone elses car. I just like most of what the did so I'm basing mine off of that one. and my drawings are just rough ideas. I'll probably end up with a rear end similar to that of the Edison2 VLC
brucepick- It will have to be since I'm not going to have a bumper anymore!
Old 04-15-2013, 01:18 AM   #6 (permalink)
It will be interesting to see how it all comes out. About 15 years ago I wanted to do that with my Tempo but never got around to it...
Old 04-15-2013, 03:51 AM   #7 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Interesting project. Subcribing to not miss any part of it.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-15-2013, 09:37 AM   #8 (permalink)
90 day: 51.82 mpg (US)
Your XFi is already capable of 100 MPG.
I assume you're talking about hitting the magic number with steady speed cruising. Any specific target speed in mind?
You'll be wanting some taller gearing too, I imagine.
Old 04-15-2013, 02:18 PM   #9 (permalink)
Hexd - '93 Honda DX Hatchback
Things look to be shaping up (pun intended) nicely for you Jim~ BUT...
Keep in mind that unless you buy from a specialty manufacturer (like ARP) over-the-counter stainless hardware is the SAE equivalent of grade 2 steel, and NOT recommended for any torqued or load-bearing responsibilities.
Valve cover bolts- okay
Bumper bolts- iffy at best, and not if towing/being towed
alternator/motormount/etc- no way~ at least not in my book!
As far as your exhaust manifolds are concerned~ best to use stock or other good quality steel, Loctite in the head, and coat with an anti-seize compound on the manifold side...
Peace~
Scott
Old 04-15-2013, 04:08 PM   #10 (permalink)
HydroJim's Avatar
MetroMPG- steady state at 60 mph. so 100 at 60. I wouldn't mind taller gearing, but the transmission that is in there is the 2nd tallest and it's working so I'll keep it in there for the time being. 3.52 are hard to find around here and i don't have the money. I could get bigger wheels, but I'm going to stick with the 12 inch stock wheels in the front for now until I get back to work. Baseball season is fun, but not working sucks...
albyneau- Thank you for the concern scott, but this isn't just any stainless hardware. it was specially put together by a member on the geometroforums so everything is all spec'd out correctly. headbolts aren't part of the kit though so I'll be using some head bolts from a guy named "Geo Glenn"
