Old 01-01-2014, 06:20 PM   #21 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
I have heard "Inboard Brakes are not allowed by certain Motor Vehicle Agencies, as the axle is now a braking member. Hard to figure, if an axle can propel the vehicle, it "should" be able to stop it too. Of course if it fails on acceleration, no big deal, failure during heavy braking...
I guess Edison did not build a production ready car...Oh well.
Old 01-01-2014, 07:29 PM   #22 (permalink)
Originally Posted by RedDevil
My thoughts ran that way, too; for an open wheel car like the VLC. The way I pictured it was to form the outer surface of the fender from the appropriate section of the Template and deal with the inner surface on a 'best effort' basis. The thinking is that air further from the body would 'see' the template shape to the extent possible. The the rears could extend to the rear of the vehicle.
With a full body I'd consider the dual wall skirt like Aerocivic uses.
Old 01-01-2014, 07:41 PM   #23 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Worked in the back of jags for decades. never heard of any law against it, and doubt any law enforcement officer would either.
Shooting for 600 miles of range at 65-70 mph out of a vx.
The Following 2 Users Say Thank You to Superfuelgero For This Useful Post:
CFECO (01-01-2014), some_other_dave (01-02-2014)
Old 01-01-2014, 09:13 PM   #24 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
Good points, I forgot about the Jags, among others. And local PD even knowing about it...LOL! I forget where I heard that, and probably will not be able to retrieve it from the depths...OH well! If I find it I'll get back to you.
Old 01-01-2014, 09:14 PM   #25 (permalink)
Reverse-Trike EV
Giovanni LiCalsi's Avatar
It will use very little disc brake pressure to stop because of the brake regeneration and the rear brake will use a front Ducati caliper.
I will use the lightest and strongest driveshafts.
I won't be racing it too hard.:^)
It will be licensed as a motorcycle.
Kind Regards,
Giovanni
http://www.steamcar.net/stanley/fastest.pdf
The Following User Says Thank You to Giovanni LiCalsi For This Useful Post:
aerohead (01-02-2014)
