Old 03-20-2009, 07:06 PM   #1 (permalink)
Novice but learning!
Race car aerodynamic help?
I am after some help, please can you see our website,
www.bennettracing.co.uk
I am after some aerodynamic advice on our race car, we simply want to reduce drag and were open to ANY ideas or suggestions.
Thanks
Luke
Old 03-20-2009, 07:45 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Hi Luke -
For which car? Can you post a link & photo?
Old 03-21-2009, 12:56 AM   #3 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Put light fairings on the roll cage and wing support tubes and any similar bits cutting air. A simple tail of folded cardboard and two wraps of hundred-mile-an-hour tape can cut the drag of those parts to a third. Light, well-shaped fiberglass wraps could be much better still. You might even get to laminar flow in clean air, if the vibration isn't too bad.
A thin metal wrap on those headers could give both streamlining and downforce, especially if the pipe angles are adjusted with that in mind.
Old 03-21-2009, 04:13 AM   #4 (permalink)
Photos are all on site under the gallery
also some photos here
Feature: Bennett Racing
Thanks
Old 03-21-2009, 09:31 AM   #5 (permalink)
Well, with how aerodynamically dirty that thing is, you'll need to start from the front and work your way back. Everything will need to be enclosed in a fairing. Avoid any abrupt angle changes. I'd try to tilt the windshield back to reduce the angle there. Once everything in enclosed, add a boat tail to the end. Tuft testing is really going to be your friend on this one.
Old 03-21-2009, 09:47 AM   #6 (permalink)
Got that book just reading through it now.
Really after things we can add without hugely changing the look of the car.
But to help it through the air a little better.
The rear wing struts we are going to change to the aero tubing which is basically tear drop shaped rather than round.
I was thinking of making an undertray for the front section too
Old 03-21-2009, 12:53 PM   #7 (permalink)
race car
Luke,is it the AA Fuel Altered that you want help on? Your all-up weight would be useful ( wet ).Are you at full lock-up with the clutch at the timing light? Is there any horsepower to spare? Is the body of the car already carbon-fiber epoxy? Does the rule-book allow any enclosure of the body/chassis for that class? Are the wrinkle-walls slipping presently at speed ( roof-top negative-lift airfoil )? Can the driver see around the engine/blower/bug-catcher at present time? Do you have your front/rear axle weight bias ? Do you have a sense of the car's dynamic weight distribution at upper speed. Do you have a time/velocity table so we can see your residence time through a velocity regime? Can you show us where the center-of-gravity of the car is. Have you ever put a model of it in a windtunnel to determine it's aerodynamic center-of-pressure. Does the car do a wheel-stand,with chassis-flecture at launch? If so,at what distance and velocity does the front wheels touch down? Do the small outboard winglets at the front axle keep the wheels firmly planted near top-speed? Can you say how much the cabin raises as the drag slicks grow to full sidewall height? Is the length of the car at it's maximum or could it be any longer? Can the wheelie-bars be enclosed? These are some considerations one would need to appraise where you presently are,and potentially where you could get to.We don't have to tell you how dynamic a dragster is,from launch to the finish line,and your driver's safety is paramount.If your going to "experiment" with the "real thing" you sure want to be safe about it.
Old 03-22-2009, 10:05 AM   #8 (permalink)
Thats a few questions ! I will try to answer them the best I can.
Yes the black Relentless fuel altered
2200lbs race ready with driver
Do you mean top end finish line? Or the start line?
How do you mean?
No fibreglass but its fairly lightweight, we were concious of this when we made it.
Pretty much do what we want...thinking an undertray?
Don'y get this one...sorry
Yeah has about an inch over the injector
It is around 800lbs over front and 1400lbs rear end
Do you have a sense of the car's dynamic weight distribution at upper speed?
None
Not sure what you mean...
Can you show us where the center-of-gravity of the car is?
Not sure how can I find out?
Have you ever put a model of it in a windtunnel to determine it's aerodynamic center-of-pressure?
I am currently trying to get it sorted, have someone ready to put a model in there but need a CAD drawing done first.
Yes, chassis must flex to enable it to put the power down
Front wheels come down at around 60 feet out or about 100mph
So far yes, we have only tested the car so far but at 160mph the car was very stable.
The tyres grow about 8-10 inches in total
We are restricted by wheelbase (centre of wheels) which is 125 inches. Everything else we can do what we want.
Yeah
I agree safety is paramount its my dad in the car so I'd like it right.
Even if there are some little things I can do/make it might be the difference between a 6.200 and a 6.1999
Thanks again all appreciate your time.
Luke
Old 03-22-2009, 11:36 AM   #9 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
I am watching this with interest as I feel that aerodynamic changes can give you the improvement in times you are looking for in a field where everyone just tries to increase horsepower.
My only question is, would an undertray be safe on a vehicle that already does wheelies? That aspect seems to present a problem IMO.
- more surface area to cause drag while in the wheelie, which will strain those wheelie bars even more, thus actually slowing you down. But I will other those that know break that down better.
BTW, without altering the wheelbase can you change the shape of the cab. Imagine a dragster with a boat tail ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 03-22-2009, 12:24 PM   #10 (permalink)
Very good question, only thing I can say is that we will be trying to contain and 'tune' the wheelie bars this year to reduce the height of the wheelies.
While a 12 inch wheelie looks good, going up means your not going forward...
An inch is plenty...but the point it def to do a small wheelie as it transfers ALL the cars weight over the rear slicks which aids in traction.
As for the boat tail, could you post a simple drawing please? We made the body and added the arches and also the part for the parachutes to go onto, as any lower its just dead air.
We can make and fabricate anything so any ideas are very welcome.
Thanks
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Getting Off Gas! bennelson Fossil Fuel Free 117 05-19-2009 12:36 PM
Article: Smart car offers fun along with fuel efficiency MetroMPG General Efficiency Discussion 0 01-29-2008 08:39 AM
