Old 04-26-2011, 11:30 AM   #31 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by steffen707 View Post
I gotta check how much insight 14" wheels weigh, because my civic vx wheels are super light but only 13".
Insight wheel = 10.5 lbs apparently: http://ecomodder.com/forum/showthrea...eels-1407.html
Old 04-26-2011, 11:39 AM   #32 (permalink)
Well that is certainly light. A long time ago i bought some 94-97 miata hollow spoke 14s that were 10.8 lbs.Table of Wheel Weights
The vx wheels are apparently, 9 lbs, but I can't find any good source for that except for honda-tech hear-say. I own a set of them, but they have tires on them. I'll weigh them after I pull the tires off. But that might not be for some time.
Old 05-14-2011, 12:13 PM   #33 (permalink)
Originally Posted by Tygen1 View Post
Zonker, I run RE92's 165-65x14 on Miata BBS rims. They are really nice for good mpg's.
HA! That's exactly what i'm going to try. Do you have the 14x6 Miata wheels? I read on tire rack that the max wheel width is 6" which is what my miata wheels are, but i'm just wondering if it has made any difference in handling, sidewall buldge, ect. ect.
I suppose regardless i'm going to try it, can always dismount them and find some other narrower 14s, but probably nothing this light, unless i go Insight wheels.
Old 05-14-2011, 09:23 PM   #34 (permalink)
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
The BBS wheels are 14x6 and the tires fit fine. Don't expect to rail corners with these tires. They are not a stiff as a regular tire and even at 50psi (which they like) they flex quite a bit. I'd consider them to be dedicated Eco tires.
Old 05-14-2011, 09:44 PM   #35 (permalink)
Oh yeah, I'm not planning to drive hard on them just curious how they fit on the 6" rims.
Old 09-24-2011, 11:02 PM   #36 (permalink)
HighMPG's Avatar
Super Duty - '12 Ford F250 Super Duty XLT Long Bed Super-Cab
90 day: 15.29 mpg (US)
They do not make them in my size =(
155/80/13! lol
Good Bye Insight Hello 6.7 Diesel Truck!
**My First Hybrid Insight**
Old 09-24-2011, 11:09 PM   #37 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
look for some 14's rims. that what i have on my corolla
Old 09-24-2011, 11:14 PM   #38 (permalink)
HighMPG's Avatar
Wont that raise my unsprung weight and tire width?
the comparable upgrade to 14 I found was 185/60/14 with a .09% difference in spedo but it would add 1.10" or so to my width which may cause more drag and resistance? I may just stick and downgrade from the 175/70/13 back to the OEM recommended 155/80/13. the tire I have on there right now the 175/70/13 is .78" wider then the stock 155 so I may get some MPG and resistance improvements from going to a 155 tire. I know a thicker sidewall height is not always best for saving on resistance but can a wider heavier wheel save me gas if the tire that fits on it is better?
