Old 06-27-2008, 04:16 PM   #11 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by Phreakuency View Post
So I took off the antennae and the bars going across the roof rack. I am wary about taking off the roof rack because there are holes that I don't know how I will cover.
The cross bars on my SUV are pretty aerodynamic. They look like a symmetrical wing shape. And, since I use my roof racks to haul long stuff around, I'm going to have to live with the drag.
----edit-----
I did lower the antenna drag by 50%. I lowered it half way down.
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 06-27-2008, 04:57 PM   #12 (permalink)
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 30.38 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
You shouldn't use silicone anything on a steel-bodied car. As the silicone cures and ages it releases acidic compounds that will initiate corrosion on any unpainted steel it contacts. The silicone windshield sealants are real bad about this and causing rust in the windshield channel. OEMs and glass shops use a gooey urethane sealant to install glass.
I'd go with the vinyl decal with some high quality 3M pressure sensitive adhesive backing or possibly a plastic plug like from Welcome To Caplugs
Old 06-28-2008, 09:56 AM   #13 (permalink)
- - '10 Toyota Prius III w/Navi
Hi All,
There is a non-corrosive silicone sealer. We use it for antenna work all the time. Its blue, and a little more expensive, and readily available. I have opened up silver plated connectors under this stuff 10 years after I sealed them, and found the coupling nuts still bright silver.
Standard RTV (Room Temperature Vulcanization) silicone is corrosive because the anti-polymerization agent is acetic acid (think orange juice,without the orange). As the RTV cures, the acedic acid is evaporating out of the blob.
This stuff is in a silver blue tube, usually, and in the gasket sealer area of most automotive, or hardware stores. It has a carboxyl smell to it. Here is a linke:
PERMATEX 81724 ULTRA BLUE RTV SILICON GASKET
The Following User Says Thank You to donee For This Useful Post:
Pawtuckett (01-29-2013)
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
WTB: Set of 13" Wheels for Geo Metro SirKeats For Sale 9 06-03-2008 06:40 PM
Signature FE images ... beta test ready MetroMPG Forum News & Feedback 44 03-17-2008 12:53 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 02:49 PM
