08-01-2019, 01:01 PM
#21 (permalink)
Cyborg ECU
another prototype
Wanting to have the flat spoiler back on the car because I'm trying to get 70 MPG and it seems to be a working mod, I decided to prototype again last night. I got the paper wrapped foam board for a dollar/sheet at Dollar Tree as was recommended earlier in this thread. It cut really easily of course. I put it in place. I gave it a layer of black remnant paint in order to give it water resistance. The paint, possibly because it's only on one side, warped the form as it dried overnight. So I found the spoiler kind of sticking up a little when I came out this morning, and it was pulling apart the duct tape connecting it to the supports under the spoiler. Here it is after I devised methods for holding it down more firmly and a little more flat... But I'm disappointed. I guess I should have painted on both sides or not painted it at all. Nonetheless, I'm going to run it. Polymetal will be the next, final version, I think.
08-01-2019, 01:24 PM
#22 (permalink)
That doesn’t look too bad? Not gonna wrap it down over the sides?
My current Ecotec project...
My last Ecotec project...
08-01-2019, 04:50 PM
#23 (permalink)
Cyborg ECU
Originally Posted by 19bonestock88
... Not gonna wrap it down over the sides?
Not on this version. This is one of the two shapes that I tested at El Mirage. It tested as being almost as effective. And since its design is simpler, it doesn't obstruct any part with a tail light fixtures, and it doesn't present complications for getting into the trunk, thought I would test it out and see how it performs on the road.
On my commute this morning it seemed to help. I know that can just be confirmation bias, but remember this is the same design that I tested at El Mirage and their a much better test showed that it does actually benefit. Anyway, my tank average is creeping closer to 70 again after two days a falling off towards 68.
08-01-2019, 08:25 PM
#24 (permalink)
Nice! Makes me wish I had tried harder to get a better on on my Civic. It's looking good!
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
08-04-2019, 03:24 PM
#25 (permalink)
Cyborg ECU
I took it off today because it was warping enough to burst all the duct tape. It just kept warping over time. I think the paper wrapped foam board is probably not a great candidate. But I NEED another model because without the spoiler again I struggle (again) to get over the 70mpg threshold. Today's morning run yielded 68.xx again. I was well over 70 in that same trip average when I took the spoiler off this morning. These are not scientific data points, obviously, but given that this is the design that tested approx 6.5% better in coast down testing at El Mirage, I am confident I am probably seeing the costs of not running the spoiler, at least in part. I may fiberglass my original cardboard template today.
08-04-2019, 06:26 PM
#26 (permalink)
That's one of the issues I had with mine. I didn't see a way to securely attach it without drilling an aluminum plate onto the hatch or doing something with fiberglass.
Maybe a cheap hatch from someone parting out a car you can drill into? but that would be quite the undertaking.
08-04-2019, 10:51 PM
#27 (permalink)
Cyborg ECU
I chose not to fiberglass today. The template is badly warped and I have no other materials. Think I could fiberglass over paper-wrapped foam board? $2 would get me enough for the experiment tomorrow. Think it might warp as the glass & resin dries?
No drilling. I still think I will want to use maybe 5 neodymium magnets, 3 or 4mm high, with countersink holes to take screws that will point upward from the decklid. A hole cutting drill bit will make it possible to set the magnet into the spoiler so it lays flush on the decklid. Maybe 4 good layers of plastidip at the magnet/trunklid contact point could reduce unnecessary paint damage. A few self locking nuts could secure the spoiler to the protruding screws on the trunk. The spoiler material I am considering making out of 6mm black polymetal. Polymetal, I am assured, will not as easily warp, like these cheaper prototyping materials have.
08-06-2019, 04:16 PM
#28 (permalink)
foamboard is really neat stuff.
worst case, 2layers. walmart FB is thicker/denser than DTFB. SO FAR seems mostly VOC proof in light applications. the stuff I make my toy planes from is gas and fuel resistant.. minwax polyurethane makes it everything resistant
08-09-2019, 08:10 PM
#29 (permalink)
Cyborg ECU
This makes me want to experiment further with foam board before committing to polymetal. So I got a little more paper wrapped foam board ($2.xx for two sections at dollar tree). I already have polyester fiberglass and enough remnant interior latex paint to try what this guy did... Five coats of interior latex paint worked for this guy:
08-10-2019, 06:04 PM
#30 (permalink)
Cyborg ECU
Last night I made a fiberglass decklid spoiler using my cardboard template as the model. Polyester resin. Dried flat over night. At 7am it was flat. At 2pm when I got home it was warped in the sun. I am really frustrated with this constant warping of every material I attempt to use. I am reading that a heat gun can render it somewhat pliable to flatten again, but I am pessimistic.
