08-11-2019, 03:33 PM
#31 (permalink)
Maybe fiberglass it in a frame and cut it out after? Else slump-formed sheet ABS?
08-11-2019, 10:46 PM
#32 (permalink)
Cyborg ECU
I gently forced the fiberglass flat yesterday and weighed it down with bricks. By morning it was holding flat without the bricks but I kept them in place and let direct sunlight heat it again all day. Just finished working it witha heat gun. Trying to learn how to manipulate this matterial for future. The thing is ugly and amature, but it is only meant to be temporary. I will make another soon. This goes onto the car before I leave for work in the morning, maybe.
08-13-2019, 10:19 AM
#33 (permalink)
Change your epoxy? Polyester resin is famous to warping when dry and taking forever to really cure.
08-13-2019, 11:59 AM
#34 (permalink)
Cyborg ECU
I already have a supply of polyester, so I am committed for now. And supposedly the polyester is the new style. A thought about making it more rigid... maybe some wire mesh, thicker than a screen, between two layers of glass.
Here is what it looks like today, after it was reattached yesterday. Ugly! I am out of black duct tape and I have some old pink duct tape from my daughter that has been laying around for years... using it up. Not gonna waste paint on this temporary build.
08-13-2019, 01:44 PM
#35 (permalink)
A later iteration might be straight-sided to that crease that comes off the C-pillar, with downturned winglets to the corner of the tail light.
08-13-2019, 05:51 PM
#36 (permalink)
Any issues with warping today?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
08-14-2019, 12:15 AM
#37 (permalink)
Cyborg ECU
Yup. But I am not entirely surprised. Polyester takes forever to cure it seems. So far it is not really serious warping, but...
Clearly there needs to be extended curing time (like a month) or some sort of structure or reinforcement within the piece. Such issues make the material less appealing. Basically, it wants to expand in the heat of the sun, and so it warps. The cardboard underside might not be helping, but I remember a previous piece I made for the interior and as soon as I took the cardboard off (soaking in water) the piece warped without heat.
Maybe multiple layers would help?
08-14-2019, 10:12 AM
#38 (permalink)
Heat affects polyester cure. Needs to be really warm and held flat for a week or so to expedite cure.
08-14-2019, 11:40 AM
#39 (permalink)
Cyborg ECU
Yes, I have been reading about that online. Some people say even as much as 30 days. I want to take back a little bit what I said about warping yesterday. Before driving this morning I went out to take a good a closer look at it, and although it has deformed it's quite slide this time, unlike that first morning after I had made it tonight before. I believe that's probably because of the heat curing I had done in the last few days. I left it waited flat out in the bright California Sun for several days, and I don't want evening I went out there with a heat gun to reinforce that heat to get it up pass the temperature is it would have been experiencing from the Sun, and then left it waited overnight and another day flat. There's no doubt about it... it has not warped as much this time as it did last time.
08-14-2019, 05:35 PM
#40 (permalink)
Glue cardboard sheets into a block and cut the part so the corrugations run normal to the long dimension.
