Old 05-22-2014, 02:08 AM   #61 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
the auto trans is a ALL OUT mpg killer, its a non O\D, non lock up trans....
add in the 4 cylinder engine 4 door and A\C and it will be very hard to brake the 40 mpg mark even with "very aggressive" gas saving driving.
going with the flow of traffic 30/34 is common for it..
theres one model the, "geo metro XFI"
the cam shaft out of it is the most valuable mpg item...
but over all the XFI was made with one purpose and thats max mpg...
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
Old 05-22-2014, 10:12 AM   #62 (permalink)
whitey - '95 toyota corolla dx
Thanks PD....I'm learning here....xfi eh? Searching locally, seems like not easy to find! Is the cam something that can be found and swapped into a more stock version?
Old 05-22-2014, 07:16 PM   #63 (permalink)
the XFI was a USA only model 1990/1994 and barely 10% of them "or less" where XFI if i remember right..as i see your in Canada
non XFI model rating...
Compare Old and New MPG Estimates
XFI rating
yes with work all the XFI hard parts 2 ring pistons, computer, trans are swappable, to a standard 1.0L engine. id say the computer will net the least gane.
when new theres about a 10hp difference in the two engines.
do to the cam reducing air flow in and out of the engine and the 2 ring pistons that have reduced drag. the XFI computer has more or less no change in the HP.
some good info on the cam swap...
http://ecomodder.com/forum/showthrea...-swap-102.html
Canada got the hot rod version of the 1.0L 3 cylinder with a turbo charger. i think it was the pontiac version up there, but as far as the XFI i think imported ones are all you will find.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 03:47 PM
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 07:48 PM
Tuning an 1993 Geo Metro Up from 32 MPG. Zorro DIY / How-to 6 04-29-2009 09:18 AM
1990 Geo Metro hatchback; improved mpg 90metro Success Stories 9 04-07-2009 10:25 PM
