11-02-2013, 03:09 PM
Regear possibilities (01 Ford Ranger)
Been a while since i felt inspired to do any ecomodding. Been averaging 36 on my commute, on winter gas, so i have been feeling pretty good about that.
BUT I have an itch to mod something right now and I am leaning towards regearing. Right now I running 3.73 gears with 215/75r15s, and my best idea so far is to try and grab a 3.08 rear end out of an 1992 ranger, which is also 1" narrower on each side, and go with some 195/65r15 LRR tires (Michelin Energy Savers A/S??). By my calculations that should be 17.4% decrease in RPMs from the gears, and a 10.5% increase from the tires. Combined this should result in a 6.9% decrease in cruising rpms, with far less rolling resistance. It should also make it much easier to do a rear wheel skirt with the wheels sitting an additional 1" inboard.
Any idea what i can expect from this gearing change? I am expecting a couple MPGs highway, but dont want to cripple my trucks 4 cyl. Is there any research about ideal % change or am I going to need and just figure it out as I go?
11-02-2013, 05:49 PM
Sure there are some limitations with a relatively small engine in a truck, but eventually you might overcome this issue messing with the camshaft, ignition timing, exhaust pipe... Well, the list goes on...
And some weight savings are also a good measure.
11-02-2013, 06:01 PM
Looking into it deeper, many Ranger guys are running 31s on 3.73s with good results on the same 2.3l DOHC(154 ft-lbs), especially on the highway. Though most prefer to regear to 4.10, because they are more offroad or towing oriented. The difference between stock tires(225/70/15) and 31s is about 12%, so my thinking may be too conservative! With my improved aero and driving style I could probably get away with a 10% net gearing change after tires and rear end swap with no issues.
Unfortunately there is not much available for power/efficiency mods on this engine without spending big money...
11-07-2013, 04:28 PM
How expensive might it be to get the head (including the cams) of a Fusion Hybrid and a supercharger? It may still be an efficient way to increase the efficiency minimizing any sacrifice to the performance, just like the old Miller-cycle engines.
11-07-2013, 08:01 PM
That is an excellent question, i have no idea on the fusion hybrid head swap.
11-08-2013, 07:20 PM
And it still seems to be the easiest mod to increase the efficiency in a 4-pot Ranger with the Duratec. Then, a supercharger would be needed to overcome the lower output due to the "Atkinsonized" cams.
11-08-2013, 08:59 PM
the main issue with the fusion swap would be the vvt, which the ranger computer cant do
11-08-2013, 11:40 PM
The main point is to get the cam setup and the increased static compression ratio, not actually the VVT. You could get a stock Ranger head modded for that matter.
11-12-2013, 06:11 PM
#9 (permalink)
A 3:08 might be a bit "tall" for the little 2.3l from a dead stop. Maybe research a 3:45 from a pre-'92 Ranger (shorter half shafts also). I think the next "taller" gear in the Ranger (pre-'92) was something like 3:27 (?). Too much gear from a dead stop and you might be wasting your "savings" in just getting up to speed. I am thinking about the 3:45's also. They seem to be about the "limit". the Duratech's probably make more torque than my little Lima so maybe you could get away with the 3:27 (?) but I still think the 3:08 is pretty tall. Just my opinion though.
If nice guys finish last, are you willing to pay the price to finish first ?
11-12-2013, 09:35 PM
#10 (permalink)
i totally agree, thats why my plan would include resizing to LRR tires down 7% (205/65/15). Doing both would net me 10% or the equivalent of 3.36 gears and less rotational inertia.
