Old 07-26-2012, 11:57 AM   #1 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Renault Clio 2 Ph.3 Ecomodding Thread
Hi
In this thread i will post pictures and diagrams of my ecomodding work.
First ecomodding job for me ,although not a very good one i guess, is a partial upper grill block.
Using a piece from 5mm depron sheet and some clear tape i made this block for testing out temperature tolorances.
ID:	11226   Click image for larger version
Old 07-26-2012, 11:59 AM   #2 (permalink)
also i've covered up some intake holes that lead to nowere ?! why did they put them there?
ID:	11228   Click image for larger version
Old 07-26-2012, 12:01 PM   #3 (permalink)
and finished job for today...
ID:	11230   Click image for larger version
Old 07-26-2012, 02:31 PM   #4 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Keep a close eye on your engine coolant temperatures when blocking as much as this in the high temperatures .
The built-in temperature gauge may not be accurate or clear enough .
It's one of the reasons many of us run a ScanGauge ( Welcome to Scangauge Homepage - www.scangauge.net ( English Version ) sell them, and they're in Patras, Greece ) UltraGauge (_____) : exact coolant temperatures.
The Following User Says Thank You to euromodder For This Useful Post:
stargazerf3a (07-27-2012)
Old 07-26-2012, 02:36 PM   #5 (permalink)
euromodder's Avatar
Also, while ecomods help to reduce your fuel consumption, changing your driving style is far more effective than many mods.
Driving slower will help a lot.
It doesn't mean you'll need more time for a relative short distance (like 50 km or so).
Old 07-27-2012, 07:39 AM   #6 (permalink)
It's one of the reasons many of us run a ScanGauge ( Welcome to Scangauge Homepage - www.scangauge.net ( English Version ) sell them, and they're in Patras, Greece ) UltraGauge or MPGuino : exact coolant temperatures.
Thank you for your answer
The built in gauge is far less than accurate , i have installed a car pc so i have all the readings through the EOBD port. Yestarday i did a 20km highway ride and the highest reading was 90c for about 10 seconds. Most of the time is was between 80-86 degrees and it is what i usually expect. Thermostat opens at 89 degrees so i think i am ok for now. As you can see the left opening which i've covered doesn't cool anything but the A/C compressor and the alternator so i think is useless for my engine , it is maybe usefull to bigger engines.
Does mpguino measure temperature? that will be usefull cause i don't turn on the car pc always it pulls 5-6 amps and that i think can ruin my MPG
Old 07-27-2012, 01:25 PM   #7 (permalink)
euromodder's Avatar
Errr ...
I thought it did.
But when looking it up, it doesn't seem to show coolant temperature.
My bad
Old 07-28-2012, 07:12 AM   #8 (permalink)
Errr ...
I thought it did.
My bad
Nothing to worry about but you gave me a great idea...
I think it will be easy to hook up the temperature sensor to mpguino and that way i'll have the pc turned off when i don't need music haaaa!!!!
Old 07-29-2012, 06:40 PM   #9 (permalink)
New record for me yestarday maybe result of MPG software i've installed to my carpc so 6.88/100km 34.164 Mpg but i saw temperature readings as much as 98degrees celsius sometimes i don't know if that's normal but i hope it is...
Old 02-12-2013, 07:12 AM   #10 (permalink)
Another Mpguino Came to Life
