Old 02-12-2013, 09:50 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Did you managed to hook up temp sensor to your MPGuino?
I'm working now on temp management system for my Berta and it will be Arduino based as well.
I've noticed that your Clio has LPG installed. There's possibility to set up dual fuel in MPGuino, it requires code changes though. But it's possible for LPG electric injectors only.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 02-15-2013, 02:43 PM   #12 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Thumbs up
My mpguino is far from ready it's been four days since i've got the arduino and i am now learning how to use it and program it but i have a great idea about the next project after i finish with mpguino.
I will built a overhead console and that will contain an arduino (consoluino :P) and a 20X4 LCD that will show inside and outside temperature, battery voltage ,coolant temperature and i want it to turn the a/c compressor on and off at a set temperature (hot greek summers ) also i want to built a lower grill cover that will open and close with a big servo that will be controlled from the consoluino depending on the coolant temperature . The console will also contain switches for car pc interior lighting and an alternator on/off switch.
Regarding your project note that if you draw temperature reading from the coolant sensor both your arduino and the ecu will measure the temperature wrong cause of the increased resistance, i had the same situation when i'd connected the LPG ECU to the engine's sensor and both measure the temperature wrong about 15 degrees celsius which is a lot. Ecu on some cars including mine control ventilation fan depending on the temperature that ecu read. You can solve this by connecting a pontetiometer parallel to the wires to decrease resistance that your beautiful berta measure. Can't wait to see it up n' ready please hurry !
My clio's lpg injectors are electronic (lovato smart) and i'am sure that they work just like gasoline ones but it conserns me the fact that the pressure is not stable on idle is 1.27 bar and on full throttle it climbs that maybe will make my mpguino less accurate.
Mpguino for both fuels ? hmm... I rarelly run on gasoline (cost 1.7 euros per liter ) except on cold startups and some times that i run out of LPG so it wont be very usefull but i want to make my mpguino to deactivate when i run on gasoline so that it won't log it as free miles...
Old 02-18-2013, 04:57 AM   #13 (permalink)
AndrzejM's Avatar
Berta has a dual temperature sensor. One sensor for ECU and second one for
temp gauge on the instrument cluster. Since you don't need temp gauge to be so acurate you may hook up Arduino to that temp sensor and after calibration you may have a very exact readings. Or you may use OneWire digital thermometer (DS18B20 for example) and have more accurate readings that you may ever need. There are cheap as chips so maybe that's a good option. I'm thinking of using two of those to measure engine coolant temp and outside temp as well.
