01-12-2023, 11:31 AM
Focused on MPG
Roof Leaks Water
I am having trouble with water leaking from my roof where I had bad seals on the roof racks on my 2006 Mariner(Escape), I have removed the roof rails, put gorilla tape over holes, sprayed a rubber coating on both sides, got the passenger side sealed up but the driver's side still leaks like crazy in a rain storm, the headliner will get soaked from the windshield to just past the B-pillar, any help would be appreciated
Thanks
Staying Focus'd on MPG
01-12-2023, 01:15 PM
What's the diameter of the hole? Headliner in the way?
.Two wrongs don't make a right, but three lefts do.
01-12-2023, 01:59 PM
Focused on MPG
Probably a 1/4in, I have put silicone in all the holes and put gorilla tape over that and it still leaks, I seen some rubber strips about 4-6 inches wide and about an 1/8in thick, I had thought about those but I am undecided.
01-12-2023, 03:09 PM
01-12-2023, 08:49 PM
Quite surprising that silicone didn't work. BTW have you never tried expansion foam?
01-13-2023, 10:22 AM
Believe it or not, car wax is a really effective mold release. My thought is the leak originates from a windshield seal failure or a weld seam in the same area.
01-13-2023, 11:47 AM
Yeah, my only leaks have been from windshield gasket and a folded seam in a firewall that was damaged from a collision.
01-17-2023, 10:57 PM
AKA - Jason
I used butyl tape to seal the holes when I drilled the roof of my Astro Van to add a rack to hold my solar panels.
I drilled the holes, cleaned the area with alcohol, put down the tape, and then bolted down the rack on top. It has been leak free for 6 years now. If you are leaving your factor rack off use a bolt and washer to fill the hole and provide for a solid cover over the tape.
https://www.homedepot.com/p/Dicor-Bu...34-5/310964213
The Following User Says Thank You to JSH For This Useful Post:
01-17-2023, 11:00 PM
#9 (permalink)
AKA - Jason
I have 5 of those in the roof of my ambulance where they removed the light bar. They used silicon and those plugs and 3 out of 5 of them leak. Right now I have duct tape (The aluminum tape actually used for ductwork) over the top as a temporary fix.
The Following 2 Users Say Thank You to JSH For This Useful Post:
01-17-2023, 11:38 PM
#10 (permalink)
Ethyl or isopropyl?
