Old 01-12-2023, 11:31 AM   #1 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 19.34 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 18.98 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.34 mpg (US)
KK Copperhead - '05 Ford Escape XLS
Roof Leaks Water
I am having trouble with water leaking from my roof where I had bad seals on the roof racks on my 2006 Mariner(Escape), I have removed the roof rails, put gorilla tape over holes, sprayed a rubber coating on both sides, got the passenger side sealed up but the driver's side still leaks like crazy in a rain storm, the headliner will get soaked from the windshield to just past the B-pillar, any help would be appreciated
Thanks
Staying Focus'd on MPG
Old 01-12-2023, 01:15 PM   #2 (permalink)
What's the diameter of the hole? Headliner in the way?
Old 01-12-2023, 01:59 PM   #3 (permalink)
Focused on MPG
Probably a 1/4in, I have put silicone in all the holes and put gorilla tape over that and it still leaks, I seen some rubber strips about 4-6 inches wide and about an 1/8in thick, I had thought about those but I am undecided.
Old 01-12-2023, 03:09 PM   #4 (permalink)
Silicone probably not adhering to the edge of the sheet metal.
Ream the hole if necessary and find a plastic 1/4" hole plug?
s.yimg.com/aah/yhst-16933743911250/1-4-white-plastic-hole-plugs-plug-buttons-caps-flush-type-44.gif
ECO-AKJ (01-12-2023)
Old 01-12-2023, 08:49 PM   #5 (permalink)
Quite surprising that silicone didn't work. BTW have you never tried expansion foam?
Old 01-13-2023, 10:22 AM   #6 (permalink)
Believe it or not, car wax is a really effective mold release. My thought is the leak originates from a windshield seal failure or a weld seam in the same area.
ECO-AKJ (01-18-2023)
Old 01-13-2023, 11:47 AM   #7 (permalink)
90 day: 29.78 mpg (US)
Yeah, my only leaks have been from windshield gasket and a folded seam in a firewall that was damaged from a collision.
Old 01-17-2023, 10:57 PM   #8 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I used butyl tape to seal the holes when I drilled the roof of my Astro Van to add a rack to hold my solar panels.
I drilled the holes, cleaned the area with alcohol, put down the tape, and then bolted down the rack on top. It has been leak free for 6 years now. If you are leaving your factor rack off use a bolt and washer to fill the hole and provide for a solid cover over the tape.
https://www.homedepot.com/p/Dicor-Bu...34-5/310964213
The Following User Says Thank You to JSH For This Useful Post:
Old 01-17-2023, 11:00 PM   #9 (permalink)
JSH
AKA - Jason
JSH's Avatar
I have 5 of those in the roof of my ambulance where they removed the light bar. They used silicon and those plugs and 3 out of 5 of them leak. Right now I have duct tape (The aluminum tape actually used for ductwork) over the top as a temporary fix.
The Following 2 Users Say Thank You to JSH For This Useful Post:
ECO-AKJ (01-18-2023), freebeard (01-18-2023)
Old 01-17-2023, 11:38 PM   #10 (permalink)
Ethyl or isopropyl?
