Old 01-03-2016, 07:17 PM   #41 (permalink)
1995 Chevrolet Impala SS (since mid-year 1994 for North America U.S.) specs review
"Cd estimated by a-c:
0.33"
Rated 33 mpg epa hwy at the time.
https://desmoines.craigslist.org/cto/5377140736.html
Old 01-04-2016, 04:34 PM   #42 (permalink)
Dark Egg - '12 VW Touraeg
Originally Posted by roosterk0031 View Post
I don't think 33mpg, epa says original window sticker 25 but based on the current standard it would be 23.
Old 01-04-2016, 04:55 PM   #43 (permalink)
When the Charger and the 300 got the 8 speed (2012) with the new pentstar 3.6 they were rated 31 mpg highway, before that with the 5 speed they were 27.
Old 01-04-2016, 05:13 PM   #44 (permalink)
I was kind of wondering if that was a miss print on that website, was just searching reviews for ratings and hadn't found any.
6 sp manual swap has already been done. This site list the CD at 0.36
Chevrolet Impala SS (1995)
The 4le60 has a .7 OD, T56 could bring that down to .5 with 3.08 stock gears. If I did the math right about 1160 rpm per mile.
Only 500 lbs heavier than a 2010 Impala that has a Cd of 0.33
Old 01-04-2016, 07:29 PM   #45 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
have you driven one of those 8 speeds? horrible. To be fair, i drove one in a '15 RAM with the hemi, but my god, from 40mph put my foot on the floor and it took a good 1.5 to 2 seconds just to find a gear and move. And news about the 9 speed seems to be worse. yikes!
Old 01-04-2016, 07:54 PM   #46 (permalink)
Our van with the same motor (3.6) only has the 5 speed but when in "eco" mode drives most reviewers and hot rodders nuts. I personally think it's doing it's job, short shifting and keeping the motor in a better efficiency rpm and load. We can get 30mpg with our minivan at 65 steady. Less frontal area and better aero along with two extra gears I have no doubt will do better then 30. The 3.6 pentstar is a great motor. I can't wait to see how adding direction injection will improve it.
But to answer your question, I have not driven anything with the 8 speed yet. It's going in pretty much everything from Chrysler and a lot of exotics use so it can't be that bad. My bet it was more an issue with learning/programming and the electronic throttle then an inherent problem with the ZF 8HP transmission.
Old 01-05-2016, 06:26 PM   #47 (permalink)
Neutral is my favorite
The Black Pearl - '03 Mercury Marauder 300A
Team Panther
Land Yacht - '08 Lincoln Navigator L Ultimate
90 day: 15.89 mpg (US)
Tank of Justice III - '97 Ford Crown Victoria HPP
Team Panther
90 day: 24.84 mpg (US)
Mid 90s Panther platform. Crown Vic or grand Marquis. Low Cd, 2.73 gears available, and tons of room!
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
The Following User Says Thank You to svt98t For This Useful Post:
The_Jed (01-05-2016)
Old 01-05-2016, 09:51 PM   #48 (permalink)
One of those with a 4.2L Essex V6 and a 5-speed manual transmission out of an F-150, and the 2.73 rear-end, might be great. And not likely to feel underpowered at all...
Old 01-12-2016, 04:45 PM   #49 (permalink)
ALS
Four doors and decent fuel mileage over 30 mpgs, RWD then I have the car for you.
Find a 1993 - 1995 Volvo 940 and make sure it isn't a Turbo. Stock NA 940's would easily get 31-33 mpg on the highway. They have a 2.3 Liter four banger, four doors, automatic.
Stay away from the Turbo's (25 mpgs) and the six cylinder 960's they are real fuel hogs.
Old 01-12-2016, 09:53 PM   #50 (permalink)
Another decent candidate might be an AMC Hornet/Concord wagon. 4 doors and early ones were V8 so fitting a good drivetrain is a non issue.
Travis..
